Home > General > 4.4 TDV8 vs D4 SDV6 |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
i had a 3.6 6 speed tdv8 FF and was undecide don either 4.4 FF or the D4 3.0L. in the end i went for the RR 4.4 and dont look back. i dont think the 3.0 tdv6 would do it for me after the tdv8. D4 would of been more practical but less fun.
9th Oct 2018 8:28pm |
Having both a D4 (albeit 2.7 commercial) and 4.4 Tdv8 the D4 is a better steer and would be more practical, but the RR is the nicer place to be. The crank issue doesn’t seem to affect the 4.4 in the 322.
9th Oct 2018 9:17pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
I have both, recently changed from a 12MY 322 4.4 to an 07MY 322 3.6 and now in a 405 4.4 and we also own a D4 15MY
9th Oct 2018 10:50pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
From another forum, details of the 4.4 ZF8 box, this guy is an engine/transmission specialist
10th Oct 2018 7:31am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
4.4 TDV8 much nicer to drive. I recall a day when I had a D4 loan car, driving into a strong west wind and it slowed noticeably. Later the same day in my 4.4 no noticeable effect. RR also much more comfortable interior.
10th Oct 2018 12:36pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
I had a D3 2.7 for 8 years and thought it was a brilliant piece of kit. I upgraded to a D4 with the 8 spd box and that was excellent with a more powerful engine and more luxurious interior (For some a step down but I liked it). The motor was excellent and never caused a moment of concern, however I did get a warranty to cover the possibility of a crank going pop on me. I think that's far more rare than we make out tbh. I bought a FF in June and have had more grief getting it sorted by the dealers than anything I suffered with the D3/4. I had three suspension compressors with the D3 and 1 with the D4. The D3 compressors were more due to the fact that the dealers hadn't replaced the relay so just burnt out two compressors in a row. Once sorted the cars were amazing family tugs with 7 comfortable seats. The reason I upgraded to the FF was that I didn't use the 7 seats for over 15 months so thought I didn't need them any more. I put a deposit on a D5 but due to business issues had to cancel. 6 months later I bought my FF AB TDV8 and the engine is a pure joy. It out cools the V6 by a mile and really stonks on with a little encouragement. If you don't need 7 seats the FF is a much nicer place to be and with the V8 it's even better. A week after getting my FF I needed 7 seats and could have done with them about a dozen times since. Doh!
29th Oct 2018 9:33am |
for me the tdv8 was the main deciding factor. after having had one its tough to not have it...
3rd Nov 2018 8:06pm |
Dickie Member Since: 14 Nov 2012 Location: Gloucestershire Posts: 71 |
Or get the best of all worlds and have a FFRR with the Supercharged petrol V8.....
4th Nov 2018 8:48pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Out of interest what turbo diesel model did you have ? , both my 3.6 and 4.4 TDs had / have no lag whatsoever. If anything the torque from tickover is incredible and instantaneous. 2015 4.4 AB
4th Nov 2018 9:05pm |
I'm happy to evidence my comment: I'm a bit of a serial LR offender and have felt victim to being a pseudo LR new product tester for quite a while now!! Not meant as a brag but more to qualify my comment about throttle response from standstill; since 2013, I've had the following models (generally each kept for 6-12 months):
4th Nov 2018 9:51pm |
I would have appreciated a more comprehensive answer but thank you. I should have mentioned both my 3.6 and 4.4 were / are remapped, however my 4.4 never had any lag while my 3.6 did have ( you are correct ) at some junctions before the remap. I have driven an 5.0 SC sport 2015 model but only for a test drive and wasnt really concerned with the low down pull !!! I bow to your superior knowledge sir. 2015 4.4 AB
4th Nov 2018 9:58pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1239 |
I would argue that the primary issue is still dependent on turbo spool up time. Gearbox shifting will depend on throttle position and engine load. The spool up of a turbo just puts that half second of delay into the engine load factor ... the rpm and boost just hasn't built up at the time of pull away compared to a petrol, so the system just delayed in realising whats being asked of it cause its looking to sense the engine load as part of its decision making. That as well as the power delivery from idle revs to load revs is delayed by the spool up on a turbo. As soon as the petrol throttle opens, its pushing out the power, the diesel will have that half second delay of going from idle revs to an rpm which will provide boost. A freelander of mine couldn't pull the skin off a rice-pudding when off boost. On boost it pulled like a train. So stand still pull away was poor. Its a double whammy - I dont really think there is much you can do about it. Unless if you know you're wanting a sharp pull away and temporarily put your left foot on the brake and put demand on the throttle pedal, getting the turbo's going then left off the brake .... it'll launch then. V8 or else ... |
7th Nov 2018 9:39am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Try planting your foot in a 3.0 D4 with sand mode selected - no hesitation at all, although sand mode has been modified in the latest vehicles to not be nearly so aggressive. |
7th Nov 2018 10:23am |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
Are people really in that much of a hurry, to worry about a very small lag when they start off |
7th Nov 2018 4:56pm |
