Home > Technical (L322) > Help with locating coolant leak. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Not sure, if you look up that section on lrparts.ru you should be able to find it and if you click on it you will get a part number to google . ReaolOEM sute will give you the BMW part number if you search for X5 same year with M57 engine
21st Oct 2018 11:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
From RAVE
21st Oct 2018 11:49pm |
tominator1982 Member Since: 10 Jul 2017 Location: Bristol Posts: 5 |
Thanks both,
22nd Oct 2018 11:46am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1240 |
Unlikely sinister. More likely to be failed / degraded seals given the age, the rubber perishes over time, not helped by the cycling of heat from the engine.
22nd Oct 2018 12:13pm |
Hi and thanks,
22nd Oct 2018 5:06pm |
In RAVE, "B" is identified as the coolant elbow which connects to the hose - coolant outlet elbow to changeover valve
22nd Oct 2018 5:19pm |
Many thanks.
22nd Oct 2018 5:25pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
tominator1982 - If you just had a coolant change, connect a hose to the radiator drain tap and put other end of hose in a collection bucket or such and save your expensive coolant to reuse it again. |
25th Oct 2018 1:00pm |
