Home > Maintenance & Mods (L322) > Westfalia detachable tow hitch
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Are there two bolts holding this badboy in place?
I've removed the outer bolt, but judging by this pic, there might be another?
Lots of penetrating oil and hammering, but it'll just move a few mm outwards, and stop. Moves with little persuasion up and Down, but not out.
Post #493333 23rd Oct 2018 9:06am
S.Hafsmo
Seems to be only one.. Guess I'll just need a bigger hammer.
Post #493335 23rd Oct 2018 9:17am
if not removed regularly they do get stuck...
bigger hammer is the way to go [and some penetrating oil]
Post #493350 23rd Oct 2018 11:39am
rjff
Agreed
On ours one bolt, the cut out on the end is for a locating lug as far as I can see. +1 on regular removal/clean/lube of parts. Cheers
Richard
Gap IIDBT
Post #493358 23rd Oct 2018 1:32pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I have had much better results using Plugas, WD40 is very good for lubricating etc but for freeing off seized parts it cant be beaten.
www.plusgas.co.uk/about-plusgas/
Post #493359 23rd Oct 2018 1:34pm
S.Hafsmo
I've only owned the car for a week, so re-lubricating the tow bar was on the to-do list. Obviously a few years to late.
The aluminium latch on the back of the swan neck was corroded through, and crumbled.
Think I'll just order a replacement.
Still have to get the square out, though.
Post #493377 23rd Oct 2018 5:49pm
DrRob
Is there a proper plastic plug that can be fitted in the square receiver? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #493386 23rd Oct 2018 7:05pm
S.Hafsmo
There is a square one with the LR logo.
Part number KYB000011, or ANR3196
Not sure what the difference is.
 2007 L322 3.6 TDV8 Stornoway
Post #493387 23rd Oct 2018 7:16pm
DrRob
Thumbs Up Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #493401 23rd Oct 2018 9:27pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Ours was similarly stuck. Try as I might, I couldn't get it out over a period of many weeks lubricating it and hammering it.
Eventually, got it up on a ramp where it required two oxy torches and a very fit mechanic with a very big sledge hammer to get it out.
Since then, I've kept it greased Smile
Post #493404 23rd Oct 2018 9:37pm
DrRob
Might try a trolley jack under it Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #493409 23rd Oct 2018 9:44pm
Balloonengineer
The slot in the removable part isn't for a bolt, but lines up with a pin permanently welded into the tube which locates the front end, stops it being pushed in too far and shares the over-run load with the bolt.
If you look into the tube, you can see it.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #493531 25th Oct 2018 9:10am
DrRob
What size socket is needed for the bolt? I ran out of socket sizes Big Cry Big Cry Big Cry 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #493883 28th Oct 2018 3:20pm
S.Hafsmo
I believe it's a 24mm.
I had to use a breaker bar with a 2ft pipe on to break it loose. 2007 L322 3.6 TDV8 Stornoway
Post #493887 28th Oct 2018 3:55pm
DrRob
Air gun here we come Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #493892 28th Oct 2018 4:22pm
