Home > Maintenance & Mods (L322) > ALTERNATOR TDV8 4.4 Removal & Refitting |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
6th Feb 2016 1:14pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
Brilliant post.
6th Feb 2016 3:07pm |
6th Feb 2016 4:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
great write up, wiki'fied... ... - .- -.
6th Feb 2016 4:35pm |
Worth noting the following:
6th Feb 2016 8:48pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
To tag on the end of this... We have changed a few alternator belt tensioners on the 4.4’s. Very easy to check yourselves especially with the pics above
6th Feb 2016 10:27pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
I'm replacing the alternator on my 4.4 TDV8 and came across this thread but the images are no longer visible - I'm at the stage where I've removed the three alternator mounting bolts and had assumed the alternator would pull forward to allow me to undo the main + cable and plug but its not moving enough - do I need to access the rear of the alternator via the wheel well area? The workshop manual doesn't provide any indication on this. Whilst I have the fan and shroud off I've also replaced the 4x idler pulleys, the tensioner and both belts too, as I had a squeak for a few minutes after starting, so hopefully this will be resolved also. |
1st Nov 2018 7:47pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
No mention of how to access the back of the alternator
1st Nov 2018 8:39pm |
Thanks Graeme, they're the images from the workshop manual with no instruction how you access them |
1st Nov 2018 8:53pm |
They were the only pictures posted in the thread that were of the alternator. I had saved the thread with all pictures intact.
1st Nov 2018 10:14pm |
To help any others that take on this job, once the 3x bolts securing the alternator have been removed, wiggling the alternator forward does allow access to the rear to undo & remove the + lead and remove the multiplug to then allow the alternator to be fully removed/repaced. NB the 3x bolts need torque'ing in a specific sequence when re-fitting, per the WM. |
2nd Nov 2018 12:19pm |
2nd Nov 2018 8:44pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Hi people, it looks like the links to pictures no longer work Too many toys, not enough time
8th Feb 2021 2:42am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
HTH, look in the:
8th Feb 2021 1:28pm |
