Home > Wheels & Tyres > Biggest tyre on 22s? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7753 |
Standard on the L405 are 275 40 22 or apparently 285 40 22 on some cars, so they should fit no problem |
6th Nov 2018 10:55pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
I am referring to an l322 though not l405 or are you saying should be fine for that? Current stable:
6th Nov 2018 10:57pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I’ve got 285/40/22 on my L322 and have no issues on 9.5” wheels with a 45 offset |
7th Nov 2018 9:19am |
Loads of people running L405 wheels & tyres on L322’s You may be able to go slightly bigger, but standard L405 tyres are definitely OK |
7th Nov 2018 9:56am |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 |
A safe option would be 285/40R22. I prefer a wider tire and have had good results with both 305/35R22 and 305/40R22 |
7th Nov 2018 11:01pm |
I was trying to go up as many profiles as I could get away with as I know they are prone to cracking Current stable:
7th Nov 2018 11:51pm |
I too was worried about cracking, hence why I went for 40 profile tyres.
8th Nov 2018 10:32am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I’ve just bought a TDV8 with Hawke Chaytons. Mine have 285/35x22 and I was wondering what improvement a 40 series tyre would make as well.
28th Feb 2019 11:58pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Aftermarket 22's are sometimes made in two offsets! One for the 322 and another for a 320 (sport) they both fit on the 322 but the 320 wheels sit further out!
1st Mar 2019 12:41am |
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 |
Using tyre rolling radius calculations 285/35/22 is the incorrect profile and gives a higher speedo error in relation to the standard land rover wheel and tyre combination.
1st Mar 2019 9:53am |
I’ve got 285 40 22 tyres on my 22” Diaco 5 wheels (9.5”) and the ride is fine. |
1st Mar 2019 10:35am |
Having left it too long and cracked a wheel I think I will bite the bullet Current stable:
14th Mar 2019 12:23am |
I had a wobble on the steering around 50-70. A bit like an unbalanced wheel.
14th Mar 2019 10:51am |
