Home > Maintenance & Mods (L322) > Another water leak |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
No part listed for o ring so must come with sensor .they aren’t expensive tbh .
10th Nov 2018 12:51pm |
10th Nov 2018 12:56pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 520 |
Blimey, no they're not expensive are they! Just assumed they'd be silly price. I'll get one and see if the leak stops.
10th Nov 2018 2:02pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
There is no O ring for the sensor as there is no fluid at that join. The sensor is a magnetic reed switch and can be removed with the tank full. The tank splitting at the seam is the most likely culprit 2007 TDV8 VSE
10th Nov 2018 2:54pm |
Hmm, that's interesting. There is definitely fluid dripping from the bottom of the level sensor. Maybe it has sprung a leak in the header tank although this one isn't that old (the old one failed spectacularly!). I'll see how it goes.
10th Nov 2018 3:18pm |
