Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Following the post by ptaroni I fitted the egr deletes purchased from eBay with a good picture guide and instructions
14th Nov 2018 2:56pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
So there’s no EML with just the blanking and no EGR software delete?
15th Nov 2018 9:27am |
As far as I can tell the egrs still work so may need a delete later but they are blanked off from the intake circuit
15th Nov 2018 9:29am |
Just been out to start the FF in the cold morning air
15th Nov 2018 10:12am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
wiki'fied |
15th Nov 2018 10:19am |
Nice one cheers |
15th Nov 2018 10:21am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Excellent write up and good news on the lack of EML. Have you read the codes to see if anything is throwm up at all that maybe wouldnt cause the eml to trigger? Also did you unplug the egrs from harness?? Thanks Current 2007 TDV8 Vogue Buckingham Blue |
15th Nov 2018 5:31pm |
No every thing stays connected I already have a egr fault low voltage I think so one of them wasn't working properly,my plan is to get a ecu delete if need be
15th Nov 2018 6:29pm |
Excellent so to reverse it in the future you just replace that pipe if needs be then too. Any noticable increase in mpg and running? Current 2007 TDV8 Vogue Buckingham Blue |
15th Nov 2018 9:20pm |
Kbald , yes reversal is as you say just put the pipes back in , careful though as I destroyed the first one trying to pull it out before releasing the bottom but the gasket holds the bottom bolts so be careful when removing and you can replace at any time
15th Nov 2018 10:41pm |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 |
EGR modification/delete - Now an MOT FAIL !
20th Nov 2018 12:25pm |
SandySix Member Since: 13 Sep 2018 Location: Chippenham Posts: 44 |
Well maybe
20th Nov 2018 12:48pm |
Also the E24 limit can be affected by EGR and if an excess amount is measured then also a fail regardless if you can “see” a modified EGR or not 2009 - L322 5.0 S/C Autobiography |
20th Nov 2018 12:54pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Each car will be different but my last emissions test had me at just slightly above half of my limit. Unless removing the EGR doubles your emissions, or the tester can see through plastic, I can't see it being a problem. |
20th Nov 2018 1:11pm |
