Home > Technical (L405) > L405 4.4 SDV8 Drive Train |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7753 |
Welcome
16th Nov 2018 9:20pm |
Bry B Member Since: 16 Nov 2018 Location: Sheffield Posts: 4 |
Thanks Alistar but the problem feels more like a worn component than a bit of swarf floating around the transfer box. It’s the delay in the prop taking up the torque from the gearbox that’s the problem . I’m going to let them do what they think always with Land Rover the cheapest fix first but I’m sure it’s no going to work. The previous visit I had to tell them the problem with the suspension knocking they replaced numerous bushes until i told them the ARC valve block was the fault Ann’s sure enough they changed it. These days they are not mechanics but fitters |
16th Nov 2018 10:26pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2304 |
A double flush then a re-calibration of the transfer case motor, not just a double flush. Its a known problem. |
16th Nov 2018 10:41pm |
Thanks for that Graeme you’ve elaborated on the 19 year old service guys explanation. Will see, the other thing is there’s a strong smell of exhaust gases in the cabin when the car get upto temperature any views on that as it’s now been in twice and they have no clue. I’ve been advised a split egr pipe |
16th Nov 2018 11:23pm |
Sorry, I can't help with the exhaust smell or comment on the possibility of a split EGR pipe. However its common for a fault for the EGR temp sensor A to be recorded which may add to any exhaust odours. The EGR temp sensor A fitted in production has been revised twice. |
17th Nov 2018 12:23am |
Thanks Graeme . Appreciate the temp sensor heads up. It’s disapointing that we have to self diagnose faults when booking in for a dealer prognosis. |
17th Nov 2018 2:19am |
