Home > Maintenance & Mods (L322) > Dealers' suspension tales |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Link to your other post:
20th Nov 2018 8:56pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2281 |
Thanks Joe.
20th Nov 2018 9:07pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
A leak wont cause a sudden drop to the bump-stops. However failure of more than 1 height sensor will trigger an immediate drop to the bump-stops, as will implausible articulation derived from all 4 height sensors which could be caused by a height sensor producing an apparently valid signal. |
20th Nov 2018 9:25pm |
Thanks greameS,
20th Nov 2018 9:38pm |
Just FYI on my 12 the dealer replaced one side only when an airbag went.
20th Nov 2018 9:57pm |
^^^ does depend on the age of the vehicle
20th Nov 2018 10:09pm |
The implausible fault wont indicate which sensor otherwise the system would simply ignore that sensor. If turning to hard lock causes the dropping and assuming that no fault codes exist for 2 specific failing sensors then monitoring the actual height values with a diagnostic tool as lock is slowly increased might (should?) show a corner changing height significantly when the others don't change much. |
21st Nov 2018 4:16am |
Goodmorning,
21st Nov 2018 9:29am |
