Home > Maintenance & Mods (L322) > EGR Sensor C fault 3.6 TDV8 - Help required. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
suggest you update your car details Jamie
20th Nov 2018 8:54pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 220 |
Good spot, amended my profile and thread title for clarity. |
20th Nov 2018 9:11pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
When our EGR’s failed, one of them had a similar fault - the resistance for the egr position was all over the place so the car was getting duff readings in terms of commanded vs actual. The other side was mechanical when we stripped it down it was worn, and notchy SDD showed this as erratic behaviour as it stuck and released etc.
22nd Nov 2018 12:20am |
Thanks I suspected it maybe the case that the EGR is on its way out. The car has done 84k so have been expecting them to go soonish.
22nd Nov 2018 7:54am |
Do you have access to SDD etc if so you can see the live data and even manually command them to check out the theory without lifting a spanner.
22nd Nov 2018 8:19am |
Yes have access to an IID, is what I used to get the fault code had planned to use it to test the EGRs but the dark cold nights have put me off something for the weekend. |
22nd Nov 2018 10:52am |
Glewpot Member Since: 21 Nov 2018 Location: Derbyshire Posts: 13 |
Hi new on here & new to FFRR ownership, quick question when the EGR starts to fail why not just remove like others have done ? Seems the cheaper option & removes the issue. Or am I missing something ? |
22nd Nov 2018 12:46pm |
I considered it, and while it’s probably fine it just didn’t feel right. Not to mention while highly unlikely if it did get picked up on a MOT it would be a absolute ballache under the new rules, and we use a fairly strict place
22nd Nov 2018 11:11pm |
That would probably be my call too, keep it stock & legal. Slightly off topic I notice you live in close proximity to me, just about to go to Alan Smith garage for full service. Who do you use & do you or anyone else no Alan Smith in Derbyshire? |
22nd Nov 2018 11:56pm |
To be honest we have looked after our own for the last 4/5 years & 40k including servicing and maintenance. Mainly because when it's in bits I like to the the opportunity to clean components up paint them, dintrol them etc. We have more cars than people so are able to have it off the road as and when required. Its actually been ok to work on so far, and we have the support of a commercial mechanic and my old man who's pretty handy! It also means the money saved on labour can be spent on some of the more niggly stuff that needs to be done. |
23rd Nov 2018 3:08pm |
