Home > General (L405) > Which early L405 is the pick?
rar110
I’m thinking ahead a few years (maybe 2021), that I might be able to afford to transition from my tdv8 L322 to a L405.
It will be at least 5 years old, so something from 2012 to 2016.
It will probably be a diesel, but maybe not. Petrols are still quite unpopular here so can be good value.
I’d be interested in owners thoughts. Thanks. ______________________________
Post #497296 2nd Dec 2018 9:10am
Dolphinboy
I’ve been told go for a minimum 2015 MY A’s they had sorted out most of the errors in the software etc by then.
Post #497351 2nd Dec 2018 7:24pm
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Didn't MY14 get the twin canbus to address the system speed issues?
Post #497353 2nd Dec 2018 7:37pm
rar110
Thanks gents. Just the sort of info I was wanting. Keep it coming. ______________________________
Post #497362 2nd Dec 2018 9:22pm
CUE99T
TBH my 2013 has been pretty bullit proof apart from a little airbag issue which was down to a seat sensor in the end (after 3 goes) but tbh I can't see an aweful lot difference in anything until the lates one. Sure you get 2016 gets a new screen etc, but tbh they don't seem as solid as the older ones which is why I just keep putting it off changing. VSE for me is the right one to go for, as things on it just seem pretty decent for the money. all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #497377 2nd Dec 2018 11:25pm
Happy with my 2013 VSE too Thumbs Up
Post #497401 3rd Dec 2018 11:38am
verydisco
My 2013 Megamiler is running sweet as a nut. more than the year, the service and type of owner will make the difference. 2015.5 MY have been significantly upgraded but you'll pay a premium over a 2012/14 for one.
with £30K you can buy a good 405 today. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #497418 3rd Dec 2018 1:51pm
rar110
Thanks for the replies. Good to know. ______________________________
Post #497514 4th Dec 2018 12:43am
rar110
The SE sounds amazing even in My13. 19 speakers. Wow.
Do these have DAB as standard? ______________________________
Post #497536 4th Dec 2018 10:13am
rar110
The MY15 gets the stop start motor. Has anyone had problems with starters wearing out or any other problems? ______________________________
Post #498690 15th Dec 2018 9:02am
rar110
You blokes with a 2013 model, what motors and how many miles/km have you done in the L405? Thanks. ______________________________
Post #498691 15th Dec 2018 9:09am
Dolphinboy
Verydisco has done 177,000 in his but with comprehensive servicing and care. His is a 4.4 tdv8 which do have the dynamic stability (corners more level than without). The jury is still out on the 3.0L sdv6. There are a lot for sale on autotrader in the uk.
Post #498695 15th Dec 2018 9:37am
rar110
Thanks.
Yes the tdv6 sounds pretty good if you get a good one. I still don’t understand how belt maintenance is done on the tdv6.
I’m more partial to a tdv8.
I’m in Oz so prices here start at about the equivalent of 40k GBP. ______________________________
Post #498698 15th Dec 2018 9:53am
Mr Tee
Recently bought a 14MY SDV8, with 78k miles and only just out of warranty and it’s epic mate. So much lighter, completely different animal to drive too. Took a while to get comfortable, controls are dead easy to use, the 19 speaker stereo is mega too!
Post #498700 15th Dec 2018 10:19am
GraemeS
Remove the radiator assembly, remove the accessory belt, remove the starter motor, rotate the crankshaft to insert flywheel locking pin, remove the crankshaft pulley, remove camshaft belt cover, insert camshaft locking pins, remove camshaft belt.
The bigger pain due to lack of access, at least on the D4, is changing the HPFP timing belt at the back of the motor which includes setting the HPFP timing.
The 4.4's HPFP is gear driven and being located at the front of the engine is much more accessible if it ever has to be R&R'd.
The biggest problem with the 4.4 IMO is that the oil filter housing and oil cooler are mounted on top of the EGR cooler and LR haven't yet realised (that I know of) that the gaskets and O-rings involved need to withstand the heat from the EGR cooler.
Post #498703 15th Dec 2018 10:52am
