Home > Technical (L322) > Rear right hand height sensor |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Would say that it wouldnt be both sensors. |
3rd Dec 2018 4:39pm |
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 |
That was my thoughts, why would both fail together? Front is still ok so would suggest it's not the compressor |
3rd Dec 2018 5:03pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
What is the fault code? Can you check the live values to see what's being reported? Also take a look at the 4x4 info screen and see if the rear right wheel is showing as way off
3rd Dec 2018 6:50pm |
Cheers Mike but it's a bog standard 2003 se so no special gadgets! Lol just remembered I joined the rac a few months ago so will test them out tomorrow |
3rd Dec 2018 7:01pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Does the height adjuster do anything? If not, it could be the compressor. Both my rears dropped down to the bump stops a while ago. It was a faulty compressor in the end. No longer FF owner but still interested. Present car Jaguar XE
3rd Dec 2018 7:13pm |
No i cleared the fault on the icarsoft scanner and it was still showing up, then the back hit the deck but front is still ok. |
3rd Dec 2018 7:32pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
With a fail on a sensor on one side, it is quite likely that the car will seek to level itself, hence why both sides are down. Just fix the sensor not working and all should be OK. Rarely does a new sensor need calibration. .
3rd Dec 2018 9:15pm |
Thanks for the advice joe I've ordered a new sensor so I'll see what happens |
4th Dec 2018 11:06am |
4th Dec 2018 11:29am |
