Home > Maintenance & Mods (L322) > Possible to deactivate/disable LED halo angel eyes?
Woofster
Canada
This is probably a very unusual/unpopular modification but I thought I'd try to ask you knowledgeable folks on FullFatRR anyway.
Is there a way to deactivate or disable the LED halo angel eye rings on the 2010-2012 L322? Do these LEDs have dedicated wires inside the front headlight assembly where you'd be able to disconnect to deactivate them?
Post #497438 3rd Dec 2018 4:12pm
do you mean the fairy lights?
these are used as side lights as well as drls....if yours are set as drls then they can be de-acivated with an iidtool....
Post #497443 3rd Dec 2018 5:34pm
Woofster
Canada
More specifically, I'm referring to the pair of round halos that go around the circumference of the front headlights, as per the photo below:
On my vehicle, they are not used as DRLs and turn on when I rotate the headlight switch/dial from 0 to either 1, 2 or Auto.
Post #497444 3rd Dec 2018 5:47pm
do you mean these,
these are the sidelights and cannot be switched off...
Post #497446 3rd Dec 2018 5:55pm
Woofster
Canada
Correct, those are the lights in question.
Thank you for your feedback, Stan. I was hoping it would be a simple wire cut or wire disconnect inside the headlight assembly and that someone here has successfully figured out how to turn them off permanently.
Post #497447 3rd Dec 2018 6:01pm
you could cut a wire to permanently disable them ,you'd also get a bulb warning error i would have thought..
why do you want to do this?
Post #497450 3rd Dec 2018 6:17pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Yes its is possible, mine went in for a service with Cam Tech Craig without them and came out with them Thumbs Up
Post #497451 3rd Dec 2018 6:22pm
Woofster
Canada
Can you confirm that there are actually wires inside the headlight assembly that can be cut? I've looked inside before while changing bulbs but haven't investigated it thoroughly to determine if such wires are easily accessible. Would these wires be running from the back of the LED halo rings over to the pin connectors at the bottom corner on the back of the headlight assembly?
Post #497464 3rd Dec 2018 7:25pm
Woofster
Canada
I've seen LED halo light retrofit kits that can be added to the earlier l322s. I believe those have dedicated wiring added to power the angel eye halos. I just wasn't sure if the stock 2010-2012 headlights would have similar separate wiring.
Post #497465 3rd Dec 2018 7:29pm
i found this which shows the wire colours [and pin numbers] for the side light..i'd cut one on the plug and see if the sides go out..
Post #497486 3rd Dec 2018 9:09pm
Woofster
Canada
This is great, Stan! Out of curiosity, where were you able to obtain this useful information?
It appears that opening the circuit at pin 1 or 4 would deactivate what is described as the "lamp side light". I suspect this will disable not just the halos around the headlights, but the long, tall rectangular side markers at the edge of the headlight assembly too, which I'm fine with.
Post #497501 3rd Dec 2018 10:08pm
i've had this diagram on my laptop for a few years now, no idea where i got it from...
Post #497502 3rd Dec 2018 10:11pm
The halo/side lights are on a plug internally so, if you removed your light and looked in through the headlamp bulb hole you can see the plug from memory...
I have a broken lamp sat on my bench, ill take a look tomorrow and let you know sir...
Disconnecting it will leave you with NO front side light you realise? Maybe illegal in your country as it would be here in the UK... Thumbs Up
Post #497512 3rd Dec 2018 11:59pm
Woofster
Canada
Thanks for your feedback, Craig. I didn't get a chance to inspect my headlight assembly for the wiring this evening but if you have a disassembled set that you can easily check, that'd be fantastic!
Here in Canada, we would technically require side marker lights to be functional in either amber or white. That said, this is generally a stipulation required for our safety standards test and is hardly, if ever, enforced on the road. Law enforcement officers usually have better things to worry about than someone's side marker lamps.
Post #497519 4th Dec 2018 5:55am
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
I read on here recently that there’s a lighting configuration specifically for Canada (and one for Scandinavia)
Maybe you have this applied and can simply turn it off via IID tool or similar ? 4.4 AdBlu Tractor
4.2 SC - sold
Post #497530 4th Dec 2018 9:26am
