Home > Technical (L405) > Where's the fusebox?
Jon S
I think I've blown a fuse in one of the auxilliary power sockets but I can't find the fusebox! (what a div!) I'm guessing it's hidden behind the glovebox but I can't seem to get this off to look and I don't want to break anything trying.
Any suggestions?
Thanks
Jon
Post #497025 29th Nov 2018 2:37pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I think one of the aux supplie fuses are in the rear compartment / boot
Post #497027 29th Nov 2018 2:47pm
Jon S
The one I'm after is the aux supply for the Right back seat
I should also say its a 2013 model (L405)
Post #497029 29th Nov 2018 2:51pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Either side of the larger drop down glovebox are some flexible bits that run along the sides. You can squeeze/press these down and it releases the whole flap to drop downwards. The interior fuse box is behind and to the left. It has a diagram on a panel which comes out describing the layout and amperage of the required fuses. Be warned they are very small and fiddly.
Post #497032 29th Nov 2018 3:14pm
Jon S
OK thanks I'll have a go at this later
Post #497033 29th Nov 2018 3:35pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Relevant pages from the manual Thumbs Up
 Cheers Ian
Kielder 4x4 Safari
Post #497048 29th Nov 2018 5:42pm
Jon S
Thanks for all the info- managed to get the glovebox off by pushing down on the two stays (not immediately obvious what I had to do tbh) then got faced with -NO FUSEBOX!! The I realised it was hiding behind some insulation, once I had removed this I could see it easily. I then realised they use MINI Blade fuses not the "usual" ones so had to put it back together and go shopping for some more fuses again!
So in summary- push on the "lined" plastic stays (not the black plastic)
- move the insulation on the left (ignore the manual as this is for a LHD car)
-get some mini fuses
Post #497785 6th Dec 2018 4:50pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
