Home > Technical (L322) > Fault lights on dash |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Voltage looks a bit low to me at idle. |
7th Dec 2018 5:23pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Your battery is discharged below 12.5v, so no its not right. The good news is, its highly likely that this is causing your issues. The control modules demand a strong voltage on start up and with those values they dont have it. How new is the battery?
7th Dec 2018 7:00pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 539 |
Had the Ctek on overnight and checked battery terminals (Ok) then spent an hour checking all fuses , checked and cleaned any other terminals I could get at, battery read 12.6 and on idle 14.6 😀👍🏻😀👍🏻, took it to a Indi who put the snap on diagnostic reader and came up with the same readings (and crank was 10.6 iirc? ), he cleared down the historical faults and only the adaptive warning lights symbol remained so he went into that and checked and removed it then sent me on my way said to keep an eye on things and call back on Monday and he will take another look to see if anything re appears,
8th Dec 2018 6:25pm |
