Home > Wheels & Tyres > improving Ride comfort L322 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6657 |
I’m amazed that you think the ride comfort isn’t good.
3rd Nov 2018 12:10am |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 296 |
235/55/20 is a smaller diameter remember the profile, 55, is a percentage of the tread width, 235.
3rd Nov 2018 12:33am |
John1000 Member Since: 08 Apr 2018 Location: London Posts: 23 |
Hi, ride is good but would like to improve it as much as I can. I am using the continentals crosscontact...car is a 2011 SC...thanks |
8th Nov 2018 8:00pm |
yes, you are right. I should go for 255 55 r20, I do not think 275 55 r20 will work thanks |
8th Nov 2018 8:01pm |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
How old are the existing tires? They degrade so slowly you don't realise how good a new set can feel until you slap them on. This might be as much a problem as tyre size. |
8th Nov 2018 8:22pm |
Ticketyboo Too Member Since: 19 Mar 2015 Location: Kilkenny Posts: 38 |
I have the Vogue SE 2010 TDV8 and my last two sets have been Michelin Latitude Sport 3 255/50 R20, okay not the SC, but the ride comfort has been excellent, grip superb esp in the wet and I get good wear (I rotate front-back every 3-5K miles), so much better than the Conti boots that were on when I got her.
9th Nov 2018 9:52am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
john, one option to improve comfort is to reduce the tyre pressures slightly by a couple of psi... |
9th Nov 2018 10:21am |
Hi Lester, they are from Nov 2016, they have 22,000 miles, thx |
9th Nov 2018 12:45pm |
thanks Stan, will try that |
9th Nov 2018 1:33pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 452 |
I bought a set of 255/55 20 Michelin Diamris Sport for my previous L322.
10th Dec 2018 12:31pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I think most people go for the L405 size which is 255 55 20 as they have a larger side wall hence improving comfort. |
10th Dec 2018 6:06pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3691 |
There is absolutely nothing wrong with the ride comfort of an L322 running the correct tyres at the correct pressures 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
10th Dec 2018 10:37pm |
