Home > Technical (L322) > Intermittent wiper relay location for 2011 4.4 tdv8
biggie1919
Hi guys im wondering you can help me ive spent all day looking for this one relay🤬
Ive checked behind the battery and theres nothing , i even removed the panel that holds the battery to see if it was under that and guess what ...
NOTHINGGG
Im stuck i dont know what to do now ive even rang landrover and they told me to check the engine bay fuse box wich was no help at all
Has anyone encountered this issue before if so please help
If anyone could send pictures so i can compare that would be great
Thanks in advance
Post #498262 12th Dec 2018 12:36am
GraemeS
The main engine fuse box relay 1 is for front wipers fast/slow and relay 2 for front wipers on/off, both standard size relays.
The intermittent function is the alternate function of the rain sensor sensitivity setting switch when the rain sensor isn't working, such as when the rain sensor's fuse has been removed. If your rain sensing wipers are erratic then ensure that the glass in front of the rain sensor is clean.
Post #498265 12th Dec 2018 2:59am
mjdronfield
Do you have a wiper issue? Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #498336 12th Dec 2018 6:31pm
Has the car had a replacement screen?
Sometimes when the screens are replaced there is poor alignment to the sensors or someone has tried to save Money by fitting an el cheapo screen and there is no rain sensing function space so the punter suddenly finds the wipers stop working on rain sensing mode! There is nothing that can't be fixed with a hammer😜😜
Post #498342 12th Dec 2018 7:27pm
