Home > Technical (L322) > Dead car
chefkenmore
Dead car
Went through some deep water last week!
Long story, short! I’ve now got no ignition lights on dash! And car won’t start! Car has thrown up most of the fault codes in its reportoire!
The car did run perfectly for 3-4 days after the water! Then the codes and no dash lights!
Any clues where to look? 2014 vogue se
Post #498476 13th Dec 2018 7:01pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Any electrical activity?? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #498477 13th Dec 2018 7:06pm
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
Assuming you've ruled out the obvious (battery/terminals) my first guess would be the ignition switch, I've changed one and it seems to be an increasingly regular occurrence, the fact that the main dealer had one in stock suggested to me that they must have needed a few?
Post #498478 13th Dec 2018 7:08pm
The deep water won't have done your alternator any favours and your car is after all a 2007, the jinxed year for alternators.
Post #498480 13th Dec 2018 7:11pm
chefkenmore
Interior lights still work, hand brake light on dash works!
New alternator 3 years ago and brand new battery 6 weeks ago!
Car did start without the ignition lights then died! 2014 vogue se
Post #498485 13th Dec 2018 7:50pm
dolph34
Have you checked voltage of battery ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #498489 13th Dec 2018 8:19pm
chefkenmore
12v then14.6 when car starts 2014 vogue se
Post #498491 13th Dec 2018 8:21pm
dolph34
I've had a ' google' and a few peeps mention the battery earth strap may be the culprit, some ran a earth grade cable from the negative terminal to the engine block. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #498494 13th Dec 2018 8:49pm
chefkenmore
My Range Rover is in the best place in Scotland! Mike Park MMP, but unfortunately Mike is so busy (been there two weeks!) that he can’t get to it!
I’ve had to walk to work a few times 8 miles, and need my car back!
So need to get this car back on the road.
Any pointers may speed up the recovery!
Thanks guys
David 2014 vogue se
Post #498501 13th Dec 2018 9:31pm
You could try a jump lead to check that.
Post #498504 13th Dec 2018 9:42pm
Sandyt
Is it cranking ?
Post #498526 14th Dec 2018 1:19am
chefkenmore
Yes it’s cranking 2014 vogue se
Post #498542 14th Dec 2018 9:43am
Sandyt
Ok so that takes out the battery harness as culprit - is it damp under drivers seat think the ECU is mounted there mine did something similar but not so severe and it just needed drying out it was a while ago when we were flooded I put a small dehumidifier in over night - have a look at the ecu and see if it is damp
Post #498546 14th Dec 2018 9:58am
chefkenmore
Thanks sandt,
Car is in the garage in Dundee, miles from here, just looking for pointers. I’m sure Mikey will be checking, when he gets a moment!
Thanks 2014 vogue se
Post #498551 14th Dec 2018 10:20am
chefkenmore
Fixed!
Faulty fuse box and ignition switch Thumbs Up
Thanks MMP Dundee, sterling service, as usual Bow down Bow down Bow down 2014 vogue se
Post #501547 14th Jan 2019 6:21pm
