Home > General > L322 4.4 TDV8 2011 too higher mileage to buy? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3064 |
depends on what they are asking for it!
14th Dec 2018 10:16pm |
Steverich82 Member Since: 10 Dec 2018 Location: Ashford middlesex Posts: 10 |
It’s advertised at £10,995
14th Dec 2018 10:22pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Sounds like a bargain, 150k should be nothing for these engines. They are only ticking over at motorway speeds and at that mileage all suspension , etc parts should have be replaced. If the service history is 100% then well worth a look. 2015 4.4 AB
14th Dec 2018 10:27pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
At least it must be very reliable onto no6 Range Rover
14th Dec 2018 10:38pm |
Thank you for the info!
14th Dec 2018 10:39pm |
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 |
Maybe preferable to a lower mileage city car, which may develop issues with the dpf's, caused by sitting in traffic and being unable to regen - can get nasty... the oil cooler can be an issue, well documented on this forum, and it would be nice to see a receipt for a gearbox/transfer case oil change at some stage in its life.
14th Dec 2018 11:49pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
See if the turbo drain mod has been done, the difference is dramatic. If you go for a test drive get on a suitable road and plant the throttle all the way down and keep it there. Watch the mirror if looks like a James Bond movie behind (loads of smoke) then budget £1000 for the mod.
15th Dec 2018 5:32am |
Turbo drain mod?
15th Dec 2018 9:02am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Plant your foot on the test drive. If it doesn’t billow a load of smoke out the back then don’t worry about the mod. That’s how I summarised it..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
15th Dec 2018 9:12am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
There's a good buyers guide in the Wiki, linked at the top of the page if you haven't looked at it. Good info.
15th Dec 2018 9:18am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3686 |
http://www.fullfatrr.com/forum/topic44115.html
15th Dec 2018 11:40am |
If everything stacks up history-wise, go for it! That’s a hell of a good price (at least £4-5k below one with 100k) |
15th Dec 2018 12:57pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1343 |
The Baltic Blue list of faults is a good starting point. Corrosion can be a problem on later 322s. Check the rear wheel arches, rear quarters, upper tailgate, tailgate support straps, brake lines and window trims.
15th Dec 2018 1:48pm |
FOr your piece of mind OP, I bought my 2004 4.4 petrol with 135,000 miles and it’s now approaching 190,000. Obviously I’ve had to replace stuff over 7 years (water pump x2, radiator, alternator, front chain guides, fuel pump) but other than that it’s been a brahmer! |
15th Dec 2018 2:44pm |
