Home > Technical (L322) > TDV8 Alternator |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
The gearshift mechanism has a white movable tab at the right rear corner that when operated will allow the gear lever to be pulled out of park. However I can't advise what has to be removed from the centre console to gain access to the tab.
22nd Dec 2018 10:04pm |
Happy Eater Member Since: 05 Dec 2017 Location: Maidstone Posts: 7 |
I've not looked on the Workshop Manual yet - but cant you isolate from a wiring perspective the alternator? |
22nd Dec 2018 10:21pm |
Looking at the wiring diagram - you should be able to pull the fuse and disconnect from the starter motor.
22nd Dec 2018 10:29pm |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 156 |
Thanks for the above, I knew there must be a way to get the auto box into neutral when dead, as there is a way to get the hand brake off by the cable pull in the boot. As far as I know by the wiring diagram the alternator is connected direct to the starter loom no fuses. If everything is under control you are not going fast enough.
23rd Dec 2018 10:14am |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
The following thread has instructions with photos, starting at page 3.
23rd Dec 2018 10:36am |
Yes your thread is one I have looked at many times for this job and I have removed way more of the front of the car than you did, and I still cant see the bolts that hold the alternator on, as I said she is on her bump stops and I cant get under it, currently cant move it due to it being locked in park, handbrake on and electrically dead but looks like I now have a lead on that and I might be able to push it into the workshop and get a jack under it and get it up on some axle stands If everything is under control you are not going fast enough.
23rd Dec 2018 10:55am |
From memory, two of the three securing bolts do have to come out from underneath. I don’t think there is any way they will otherwise come out. I would have thought that was possible with it on the bump stops, but clearly more difficult. As you say, few options if not - except to get it lifted somehow. I might be tempted to get a breakdown company to take it to a garage, or is that admitting defeat! Current: 2010 Range Rover L322
23rd Dec 2018 11:02am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Can you first disconnect the alternator cables so you can get a bit or power into it?
23rd Dec 2018 11:42am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1694 |
It's all done from above
24th Dec 2018 10:53am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Ditto all from above, i still have no idea how it comes out you just kind of wiggle it until it seems to just slide out!? From memory I disconnected the cable, followed by the two lower bolts and finally the pivot bolt. No need to remove the turbo or intake pipe.
24th Dec 2018 6:52pm |
There was no way mine was coming out until I got some big zippy ties and pulled the turbo intake hose down to the chassis. fell out then.
25th Dec 2018 10:49am |
I wouldn't be putting it back together without a brand new alternator in place |
25th Dec 2018 1:34pm |
All sorted new belts ect, but I am getting some strange things happening where the battery went flat.
29th Dec 2018 10:28am |
