Home > Technical (L322) > Brakes groaning |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
That’s correct.
4th May 2018 2:54am |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 |
still trying to get this thread to dan but not sure how too |
9th May 2018 5:47pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 510 |
Just copy the link to this thread and start a new thread in the Duckworths channel referencing it? Or send him a PM with the link? 2016 Skoda Octavia VRS Estate
9th May 2018 6:16pm |
sounds easy but you are talking to a halfwit tehcnophobe |
9th May 2018 6:41pm |
Here's the link you need:
9th May 2018 7:38pm |
Keep in mind that I fitted the new dampers after fitting new struts.
10th May 2018 12:34am |
thanks for your help mate |
10th May 2018 12:23pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
10th May 2018 2:17pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
The six pot calipers on my 4.4 TDV8 seem prone to this.
25th Dec 2018 6:44pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
If you look up the spec of the lock tite LR use, it details how to release it. After spending several hours trying to remove one I looked up the lock tite and it needed heat to release, heated it to the temperature stated and they literally can just be screwed off by hand (with a glove obviously). If you use a infrared thermometer you can check no heat is dissipateing into the damper. They are just blocks of Ali, not sure how one could fail? I always assumed they were to be replaced because without heat they are a nightmare to remove |
25th Dec 2018 7:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
25th Dec 2018 7:55pm |
I think it’s Loctite 648, LR calls for STC5055 which cross references to Loctite 648 and can be seen in most of the pictures selling STC5055
25th Dec 2018 9:48pm |
