Home > Wheels & Tyres > Wheel/tyre swap and now rubbing - L322 |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
If it’s rubbing from the rear, the arch liners can be adjusted with a self tapper, used to be a bodge when larger off-road tyres were fitted. The rubbing on the front migh5 be from the bottom plates end of the strut, almost like a plastic split pin that can be cut off. If you search for I think cooper Zeons, the threads should come up |
22nd Dec 2018 5:08pm |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 |
It would be helpful to share what the wheel specs are (width and offset) and also which areas it is rubbing. |
27th Dec 2018 1:56am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7643 |
You’ve gone from the sidewalls being 35% of 265 mm to being 40% of 295 mm, so I’m not that surprised. The whole thing is bigger in the wheelarches. 2011 Range Rover Vogue SE 4.4 TDV8
27th Dec 2018 3:41pm |
Ramsden78 Member Since: 23 Sep 2018 Location: London Posts: 42 |
Not sure about offsets etc. I know next to nothing about tyres/wheels I am afraid. Assuming all alloys are the same offset I will detail them below.
27th Dec 2018 9:52pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3696 |
295/40/22 on an L322 is bonkers, they are 33mm oversize in diameter than std and are 40mm wider than std on an L322
27th Dec 2018 10:42pm |
Thank Vogue, you seem to know what you are talking about and the type of help I was hoping for..
28th Dec 2018 1:31am |
The 265/35 you have are too small in diameter for a 322, my guess those wheels and tyres were originally for an older series 1 Range Rover Sport as they ran smaller dia tyres.
28th Dec 2018 4:56am |
Ramsden78,
3rd Jan 2019 12:38am |
Ramsden is running a 322 - is that modable as per the 405? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
3rd Jan 2019 6:48am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
285/40/22 is the widest 22 you can go without rubbing. Have run these personally. 2014 FF Autobiography 5.0 SC
3rd Jan 2019 3:41pm |
I’ve got two sets of tyres and wheels on an L405, 275 and 285’s - the 285’s catch on full lock on std RR rims. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
3rd Jan 2019 7:03pm |
Hi guys,
3rd Jan 2019 10:08pm |
should have went 40's for extra sidewall :shrug: 2014 FF Autobiography 5.0 SC
7th Jan 2019 5:17pm |
