Home > Technical (L322) > Non Start, No power to instruments |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
battery....
2nd Jan 2019 5:12pm |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 76 |
So I’ve been over to it after work....
2nd Jan 2019 9:23pm |
thats a plan ..once the new fresh battery is on you'll have a starting point [hopefully] |
2nd Jan 2019 9:28pm |
That’s my way of thinking.... 2008 TDV8 Vogue SE
2nd Jan 2019 10:13pm |
88inchthing Member Since: 03 Jan 2019 Location: Cambs Posts: 2 |
Hi
3rd Jan 2019 12:17am |
Interesting, that was my other concern..
3rd Jan 2019 9:44am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
When I changed the switch on my previous td6 it was just the switch. There was no need to change the key.
3rd Jan 2019 11:46am |
Ok... so brand new battery has made no difference... so can rule that out..,
3rd Jan 2019 7:56pm |
Just noticed that my brake lights come on and stay on with ignition as well....
3rd Jan 2019 8:16pm |
Just had a guy comment on this on another forum..
3rd Jan 2019 10:00pm |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 |
on the later ff like your car there is a fair bit of work to get to the switch-sadly.... |
4th Jan 2019 1:15pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
When I helped diagnose the switch on a TD6, there was low voltage and no voltage on some of the fuses that are fed from the ignition switch. The TD6 has multiple feeds coming out of different parts of the same switch , not just one wire . Didn’t even need to remove the fuses, just used the pointed probe on a multimeter in to the top of the fuse.
5th Jan 2019 9:52pm |
So...
5th Jan 2019 11:32pm |
Joy !! |
6th Jan 2019 1:55am |
