Home > Maintenance & Mods (L322) > Shark Fin Aerial Retrofit
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
Just installing a new android head unit with dab+. Have read much that a glass mounted dab+ aerial is a waste of time due to heated screen, so curious if anyone has had the balls to drill a hole in the roof and mount externally??? Would like to fit a shark fin at the back if possible but has anyone else done this yet?
Post #500474 3rd Jan 2019 11:21pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
I've got a dab antenna mounted on the rear, left windscreen (trunk). Excellent reception. Much better than my previous car with antenna in the front windscreen. 2007 L322 3.6 TDV8 Stornoway
Post #500478 4th Jan 2019 12:02am
MadL322
as in the glass mounted one?
Post #500482 4th Jan 2019 12:30am
I have the same, and reception isn’t too bad at all, even in Scotland Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #500485 4th Jan 2019 12:41am
MadL322
so you went with the glass mounted one also? mounted in the rear window?
Post #500486 4th Jan 2019 12:43am
S.Hafsmo
Glass mounted, yes. 2007 L322 3.6 TDV8 Stornoway
Post #500497 4th Jan 2019 11:33am
