Home > Technical (L322) > FBH isolates motor coolant from the FBH and cabin coolant? |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
With yours being a v8 petrol have you even got the FBH ? |
12th Jan 2019 10:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
i thought it did both...loads of info in the wiki.. |
12th Jan 2019 10:17pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
I have a Defender with the same heater in but no diverter valve so it heats both the engine and vehicle interior so there is nothing in the heater to stop you removing or disabling the diverter. I think in the handbook it says something about heating the engine rather than the interior if it is below -20 so I wonder if that temp cold be changed. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
12th Jan 2019 10:18pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
As I read it, the FBH operates in parked heating mode to only heat the interior, thus the changover valve sets itself so the coolant goes to the heater matrix only, circulated via a pump in the FBH. Thus not heating the engine.
12th Jan 2019 11:08pm |
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 |
Yes 100% I have. Have repared the damn fbh control circuit and replaced the burner. |
13th Jan 2019 8:38am |
Afaik
13th Jan 2019 9:24am |
D3;s without park heat - FBH heats the coolant only and quickly. I use this every day and the engine temp is displayed on dash at start up so happy engine starts every time and immediate warm air shortly after start up. |
13th Jan 2019 11:48am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
IIRC, diesels need the FBH as it takes so long to get warm so are fitted as standard (although many don’t have park heat option)
13th Jan 2019 1:42pm |
Totally awesome car. I would like to find these same rims for the winter tyres too, but unfortunately these are quite scarce here in Finland.
13th Jan 2019 4:13pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I recall reading somewhere that when the temperature drops below a certain value (can't recall what exactly, I'm afraid, but it was quite cold), that the system changes focus and warms the engine coolant instead of the heater circuit. 2010 4.4 TDV8 Vogue SE |
14th Jan 2019 9:21am |
