Home > Technical (L405) > Burned engine oil odor in cabin MY 18 SDV8 |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
Could it be that they found the leak, changed the gasket but didn’t clean up the spillage = burning off?
26th Jan 2019 10:50pm |
Lonfred Member Since: 13 Dec 2017 Location: Spain Posts: 40 |
Thanks. Could be like that. I give it another week to try to burn it of. If the odor then still is there then back to the dealer. |
26th Jan 2019 11:06pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7762 |
There was an issue that some had with exhaust fumes -
27th Jan 2019 8:52am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Visible smoke in that area can be exhaust from the fuel burning heater, it comes on automatically under 5 degrees C, I don't know if that is relevant in Spain just now. If you drive only a short distance and then switch off, the car needs to burn off the fuel in the heater and that produces the visible smoke. It might make its way into the cabin if there are insulation gaps etc. The smell is unpleasant and unhealthy too, one would not want it in an enclosed space. Only Range Rovers since 1988 |
28th Jan 2019 2:21pm |
