Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2330 |
Sounds similar behaviour to my previous TD5 D2 when the MAP sensor became very clogged. Only use a spray cleaner inside a MAP sensor because solid objects such as wire risks damaging the sensor. Your engine has 2 MAP sensors. |
3rd Mar 2019 10:41pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 595 |
I did try cleaning the map sensors back in December however I would imagine at least the o/s one will be contaminated with oil again due to the turbo.
4th Mar 2019 8:22am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Injectors need a clean would be my guess.
4th Mar 2019 10:06am |
Hi Grofus,
4th Mar 2019 4:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34966 |
inlet manifold cracked?? |
4th Mar 2019 5:01pm |
I have considered a possible cracked inlet manifold Stan. Would this give me codes though as the MAPs wouldnt be reading correctly?
4th Mar 2019 6:55pm |
Ok so i removed and cleaned both MAP sensors. The left hand one was very oily as expected. I also cleaned the intercooler pipe on this side of residual oil.
4th Mar 2019 11:18pm |
Hopefully the poor running will have been fixed for the time being. |
5th Mar 2019 3:07am |
Things are getting interesting.. RR driving crap again this morning so decided to repeat exactly what I did last night.
5th Mar 2019 11:24pm |
Another small update,
10th Mar 2019 8:53am |
Cleaning the MAFs would be appropriate although if you have an IIDTool then you could compare airflow readings and compare left and right boost too. |
10th Mar 2019 10:31am |
It's not unheard for one of the lower turbo hoses to fail. There are 6 in total. 2 are short near the turbo and 2 longer to the intercooler and the 2 top ones that always fail. You can normally hear a boost leak.
10th Mar 2019 1:54pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Cracked inlet manifold gives turbo boost pressure faults.
10th Mar 2019 2:25pm |
Thanks again all for your suggestions.
10th Mar 2019 5:06pm |
