Home > Maintenance & Mods (L322) > Access height door switch
Reformed
The access height button on the drivers door doesn't seem to be working. I can lower and raise it with the switch on the centre consol but not the switch on the door. Is there a fuse for this? I can't find anything? All the other switches are fine. Reformed
Post #50757 18th Feb 2011 2:03pm
dan_uk_1984
There is no separate fuse - however if your door card has been off it may have not been plugged back in correctly.
This switch only works with ign on, although on later years I believe it works after ign off.
Post #50758 18th Feb 2011 2:28pm
after 8 years of use it might be the contacts are no longer 'contacting', whip it out and have a look.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #50759 18th Feb 2011 2:34pm
daveo
was the wire on my one when i first got it,as dan said the door card had been and the wire was not put back right V8 facelift Range Rover Autobiography 22" wheels.
Post #50784 18th Feb 2011 6:48pm
Reformed
Thanks guys. Do I have to remove the door card to get at the switch or can I remove the tweeter speaker above it and pull the switch up to have a look? Reformed
Post #50787 18th Feb 2011 7:27pm
M44K TS
I think the switch pack is screwed in from behind the door card so you will have to remove it.
I think there's a post on here somewhere which tells you which screws to remove and where the clips are located. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #50790 18th Feb 2011 9:33pm
