Home > Technical (L322) > 2012 TDv8 56k miles, White/Grey smoke and oil use |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3689 |
Have a good look for any signs of oil in the coolant tank and also any leaks around the oil cooler and down the back of the engine.
7th Mar 2019 11:16am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
coolant tank is good and clear, no leaks from oil filter housing or the oil feed pipe at back of engine Cheers
7th Mar 2019 12:35pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
What are those error codes James?
7th Mar 2019 1:02pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
P042B Catalyst temperature sensor – circuit range/performance (bank1 - sensor circuit 2)
7th Mar 2019 1:20pm |
Pulled air intake yesterday, passenger side full of oil. Backfeed from cosv, Also oil in intercooler outlet. Cheers
10th Mar 2019 8:16pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
Have you confirmed that the turbo drain mod was indeed done? The revised drain can be spotted looking up towards the back of the engine from near ground level in the vicinity of the left headlight. |
10th Mar 2019 8:41pm |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 |
those symptoms are what i would expect of a vehicle overfilled with oil/passing oil
11th Mar 2019 11:12am |
Darin mod def been done, in my ownership. it cured a problem at the time with using engine oil, this was approx 15k ago. 2 years.
11th Mar 2019 12:39pm |
Adding 3L of oil relying on the electronic sensor is fraught with danger. I urge you to not rev the engine and to immediately get the oil drained and refilled with the correct volume regardless of what the sensor is showing. If the sensor shows that a lot of oil is still needed then have the sensor replaced. 3L more oil in the engine than meant to be is risking at least blowing seals everywhere and the likelihood of a runaway engine. |
11th Mar 2019 8:45pm |
ok, i will drain it tomorrow or wednesday and refill.
11th Mar 2019 10:18pm |
I think 9 litres is too much as a starting point.
11th Mar 2019 10:34pm |
ok 8l thanks.
11th Mar 2019 10:35pm |
That pipe goes to the change-over valve. The oil could be there because the sump is over-filled or due to a failure of a turbo or possibly the crankcase ventilation system.
11th Mar 2019 10:46pm |
thank you for info on the pipe.
11th Mar 2019 11:03pm |
