Home > Technical (L322) > approach lights
dazza1983
approach lights
Anyone put led approach / mirror puddle lights in?
I see powerful uk do a set but dont like the idea of fititng a resistor in line when there must just be canbus t10 bulbs out there? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #508798 15th Mar 2019 11:33am
many have..you do have to wire in an existing bulb or a resister in line on one side only to get the leds to work properly.
Post #508802 15th Mar 2019 11:52am
dazza1983
Only on one side?
Ok cool.
Seems strange that you can’t get a canbus bulb with resistor built in? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #508806 15th Mar 2019 12:29pm
samarney
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Ipanema Sand
I've found that the resistors aren't necessary, actually wouldn't work with them but have been great since July last year without.
I got the full vehicle set off e-bay https://ebay.us/tf1lJC - NOT recommended though as almost every bulb other than the puddle lights has needed to be replaced Sad
Post #508931 16th Mar 2019 5:57pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
What type of resistor needs to be used? Thank you!
Post #555313 25th May 2020 10:17pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
https://www.ebay.co.uk/vod/FetchOrderDetai...2749.l2673
Fitted the above led’s all still working except for 1 reversing light bulb which I have had to replace. Includes all interior lights and mirror puddle lights 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #555319 25th May 2020 11:41pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Dunno about the later models but on my 2003, I just fitted LEDs without resistors nor the original bulb in circuit. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #555320 26th May 2020 2:18am
clemenz
Problem is, i bought the complete puddle
light in Led from China, when one side is bulb and the other led its okay. both sides led they will only flash and then go dark, so i need a resistor. i’m not sure how much ohm to use?
Post #555322 26th May 2020 6:53am
DrRob
Re: approach lights
See here for mirror puddle ones:
https://www.fullfatrr.com/forum/topic55197.html
Work perfectly.
Interior LEDs next - the Amazon kit mentioned in same thread.
https://www.amazon.co.uk/dp/B07CRM1HPH/ref...WEb8EKM712 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #555323 26th May 2020 7:32am
Re: approach lights
Far easier to chop the live wire and wire it into the live for the lower door lamp Thumbs Up
Post #555447 26th May 2020 11:21pm
