Home > General > What's your mpg? |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 77 |
4.4 TDV8
21st Mar 2019 11:21am |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 266 |
32 mpg - I’ve been really pleased with this. 2016 SDV8 AB |
21st Mar 2019 12:33pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
If you do longer runs at motorway speeds, certainly 20+ mpg is achievable. I average about 21 mpg with a mix of cross London and motorway journeys.
21st Mar 2019 3:49pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
@PaulBrown. Thanks for that, good to know My commute is only 10.5 miles with highway with only the last mile at slow traffic. should hopefully get closer to 16 eventually Formerly happymadison1978 |
21st Mar 2019 3:59pm |
Stephen - I'd hope that should be fairly easily achievable - I find as long as you can keep a consistent speed >30 mph, reasonable mpg is possible even with the 5.0 S/C. It's the stop/start driving and bursts of acceleration that really hammer it.
21st Mar 2019 4:37pm |
Blueboy1 Member Since: 11 Oct 2016 Location: Cumbria Posts: 15 |
I have not long got a 2011 4.4 tdv8 changed from a td6 3.0 2004 and must admit I have a heavy right foot and was getting 19mpg in the 4.4 but drove it sensible today (boring) and got 31 mpg on a 45mile journey so happy with that mind you I did not get it with mpg worry in mind love the big girl, have a LC which is my play toy for a bit of a blast which going quick can get that to under 10 mpg |
21st Mar 2019 6:52pm |
Thanks Paul!
21st Mar 2019 7:46pm |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
L322 4.4 TDV8
4th Mar 2023 5:59pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2719 |
Mine's doing a steady 30mpg average and this is mostly M-way at just under 70mph. Fuel offset via IID is now at -5% as this is closer to the actual fill to the brim calculations. Had thought that after having the new thermostat fitted and it's now running at the proper operating temperature (closer to 90 deg rather than 70 deg) it would run more efficiently but I'd say it's using a bit more fuel now.... 2012 TDV8 Vogue (L322) |
4th Mar 2023 6:05pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3063 |
2011 TDV8.
4th Mar 2023 7:00pm |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 161 |
I am averaging 31.4 mpg in the Westminster 4.4tdv8. I have seen as high as 37 on a run at around 60 - 65 mph.
5th Mar 2023 11:15pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Do some folks REALLY just believe the dashboard readout? Surely not?
6th Mar 2023 12:45am |
take 10% off the computer reading and you will be about right. |
6th Mar 2023 1:26am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 717 |
I log my mileage and fill ups and there are big differences in the computers accuracy between manufacturers. My FF is by far the worst at close to 9%, my BMWs were 3-4% out and the closest is my wife’s Golf R, which has a 0.8% variance over 45k miles.
6th Mar 2023 7:44am |
