Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1699 |
Having the EGR blanks remove and the PCM flashed back to standard would be a much cheaper option... |
19th May 2019 5:29pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
Do you have silicone hoses fitted? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
20th May 2019 11:43am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 594 |
Yep BAS silicone upper intercooler hoses fitted Andy. |
20th May 2019 12:13pm |
I’m looking to buy a pair as I think mine have seen better days and might be struggling with the extra boost from the remap. They aren’t visibly torn or cracked but I think they may be porous or too soft and collapsing every now and again. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
20th May 2019 12:29pm |
From the sounds of it, it's the only thing to be eliminated before putting a new turbo on the car... |
20th May 2019 2:28pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Is it possible you had a slight boost leak before the re map?
23rd May 2019 6:47am |
What’s the latest on this issue? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
3rd Jun 2019 3:43pm |
Well I dont believe it.. and neither will you guys.
31st Jan 2020 9:12am |
There’s a Jonah a foot 2007 3.6 TDV8 |
31st Jan 2020 10:06am |
So that little trick of removing the upper intercooler pipes and refitting works on this car too!
31st Jan 2020 5:56pm |
Have you tried either car WITHOUT the EGR blanks fitted? |
31st Jan 2020 10:23pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Is it possible the new car has a split in a hose that may have been caused when you removed them? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
31st Jan 2020 11:00pm |
Yes Mikey,
31st Jan 2020 11:06pm |
On this car are you getting any fault codes? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
31st Jan 2020 11:23pm |
