Home > Technical (L322) > 2011 tdv8 is this normal
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi
I’ve just taken the airflow pipe off to replace the belt tensioner and came across this 🤔
The car has done 75k and not sure if this would be a normal build up for that mileage, the car runs good
Any thoughts or advice.
I’ve not noticed any smoke on hard acceleration, just checked and it’s not had turbo oil drain modification done.
Post #516398 24th May 2019 11:43am
GraemeS
You'd be shocked at the muck behind the butterfly if you consider that to be bad. It's caused by crankcase oil vapours mixing with EGR soot
Post #516404 24th May 2019 1:03pm
srpara
Yes did notice the crap behind the butterfly, so from the jist of your answer this is a normal thing to happen?
Post #516411 24th May 2019 1:56pm
GraemeS
Unfortunately yes it's normal unless EGR is mapped-out.
Post #516413 24th May 2019 2:00pm
srpara
EGR not mapped, im waiting for parts to arrive which will be on Tuesday with luck .so gives me a few days to strip it off and give it a good clean.
Thanks for your advice Thumbs Up
Post #516417 24th May 2019 2:20pm
srpara
Clean up done can’t believe how much crap I got out the inlet manifold is half it’s weight 😁
Post #516643 27th May 2019 10:07am
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Jeez, what is that thing in the last two pics with the carbon deposits, and how do you get to it? 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #516684 27th May 2019 5:36pm
srpara
It's the pipe that connects the EGR valve to the inlet manifold and it's located at the top of the engine you can't miss it when you take the engine cover off
Post #516704 27th May 2019 8:02pm
srpara
If you look at the first picture in this post you can see the end of it just behind the throttle body butterfly
Post #516706 27th May 2019 8:08pm
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Sounds like an easy enough job.
Has the clean up made any difference to the driving experience at all???
Post #516769 28th May 2019 1:06pm
srpara
Haven’t got to driving it yet as I’m doing a top to bottom and front to back service on it,
Whatever I find that is knackered or looks a bit iffy I’m replacing which so far has been engine front belt tensioner and pulleys, disc and pads all round, all metal brake pipes as very rusted, engine oil plus air/oil/fuel filters, replace antifreeze, new starter motor ( got the dreaded click) diff oil x2, transfer box oil and new filter/ pan on auto box, also checked the rear o ring that leaks but my one is good so far Very Happy
Awaiting delivery of the upper and lower rear knuckle joints for both sides as one has slight play in it also replaced front suspension arms and swivel joints on both sides, I’m sure I’ve forgotten some bits but that’s how far I’ve got so far Very Happy
Post #516771 28th May 2019 1:57pm
ur20v
A Trap
I didn’t know the egr pipes had holes in them, mine and all the photos look like they are solid tubes. Didn’t bother cleaning mine, just stuck them in a bag on the shelf in the garage just for prosperity 👍
Post #516787 28th May 2019 4:26pm
srpara
With out a hole in it how would the egr gas get into the air intake 🤔
Post #516895 29th May 2019 9:12pm
GGDR
With this so gummed up, what would the effect be?
. Cheers, Greg
Post #516897 29th May 2019 9:24pm
srpara
I didn't notice any difference only reason I noticed it was because I had to take off the air intake pipe to change the front belt tensioner.
I would think if it did blocked would be like having EGR blanking mod done but without the hassell Very Happy
Post #516903 29th May 2019 10:52pm
