Home > Technical (L322) > Towing electrics |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
Could you take some photos of the 'bar, sockets and the interior socket/plug in the spare wheel well for us?
16th Jun 2019 9:21pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Gap report that when fitting to your car you don't need to tell the car you've done anything as it should recognise you've plugged into the socket provided -- as stated a photograph of the socket in the wheel well should help a diagnosis. Current: 2011 FFRR Vogue SE 4.4 TDV8
17th Jun 2019 9:29am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 522 |
I'll try and get some photo's up shortly. The towbar is made by AI Towbars of Sheffield if that's any help. Thanks. Drives:
18th Jun 2019 8:21am |
The bar itself isn't really relevant Current: 2011 FFRR Vogue SE 4.4 TDV8
18th Jun 2019 9:39am |
Well, I finally had a root around in the spare wheel well today and found the grey multi-pin socket for the towing electrics. Lord knows why someone has gone to all of the trouble splicing in the wiring, I can only assume they had no idea they are plug and play.
1st Dec 2019 6:28pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
I fitted a genuine LR 13 pin to my 2011 4.4 tdv8. Plug and play. Only tricky bit is getting the rubber grommet to sit properly in the bodywork hole. Used some silicone spray as lube
1st Dec 2019 7:23pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I know this has been asked before but I can't find the information now.
12th Feb 2020 9:09am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
In answer to the OP & kooky the PF Jones Kit is "plug & play" - fitted one to my 03 plate L322.
12th Feb 2020 9:51am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3200 |
P F Jones supply the Westphalia towbar which is , IMO, the best for the RR. I fitted one and I also fitted 13 pin electrics. I also have an adapter which means I can use the 7 pin for a trailer I have. With a removable flange (AKA Farmers) hitch it is very discreet when not in use. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
12th Feb 2020 11:28am |
Personally I thing any RR (except for the Sprout) looks undressed without a towbar. 2003 Range Rover Vogue TD6 |
12th Feb 2020 11:46am |
Thanks, I was just trying to work out which type of socket would be best to get. Sounds like the PF Jones kits will be ok then. The genuine LR ones are MUCH more expensive. Do they do anything the PF Jones ones don't? 2010 4.4 TDV8 Vogue SE |
12th Feb 2020 2:47pm |
The LR Genuine 13PIN kit is worth the extra £ IMHO. And it's plu and play for a 2011 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
12th Feb 2020 3:10pm |
Yes. They charge a lot more for something that does exactly the same! John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
12th Feb 2020 3:15pm |
Normally I would always go genuine, but it's more than 3 times the price of the PFJones one for what appears to be exactly the same thing. The PFJones one should be plug and play too shouldn't it? 2010 4.4 TDV8 Vogue SE |
12th Feb 2020 4:05pm |
