Home > Technical (L322) > Help - D post trim refitting the rubber grommets
SCPB
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Help Big Cry
I bought two new external black plastic trim panels to go on the D posts of my 2010 L322.
I then realised that to remove the 4 plastic rivets that secure the inboard part of the panel, you have to drive the centre pin, through the rivet, a couple of which end up inside the cavity. There is also a little rubber cup that goes through the hole, to presumably seal the cavity behind.
So I ordered 8 new plastic rivets (4 for each side) but apparently the rubber cups that they go into are seperate. So I then ordered 8 rubber cups as well , this is what the rivet and cup look like.
So far so good....now a week later, I just cannot remember whether the rubber grommets are inserted first into the metal bodywork and then the panel sits on top of the grommet head and then the rivet goes in. It makes sense as it would best seal the cavity but the panel obviously sits proud a little because it is sitting on the top of the grommet head. Like so....
Or, does the panel go on first, then insert the rubber grommet then insert the rivet like this...
Big Cry Embarassed :oops
I appreciate that this is not something you remove every day but does anyone know or can lift their tailgate and see if the head of the rubber grommet is visible under the rivet head or not.
Incidentally, the rubber grommets are nearly £30 for the 8 of them plus £10 for the rivets, so I only want to do it once. Shocked
Thanks in advance. 2010 5.0 SC Autobiography
Post #521385 10th Jul 2019 7:34pm
SCPB
Sorted: I used the indent/marks on the old panel to work it out. The rubber grommets go in first to seal the cavity, as I through, then the panel goes on top and then the rivet goes in Very Happy 2010 5.0 SC Autobiography
Post #521395 10th Jul 2019 9:37pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
So much more satisfying when you work it out yourself isn't it? Thumbs Up Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #521397 10th Jul 2019 9:56pm
SCPB
Very true, I just can’t believe that I couldn’t remember....Doh! 2010 5.0 SC Autobiography
Post #521399 10th Jul 2019 10:09pm
