Home > Maintenance & Mods (L322) > Auxiliary Battery now fitted
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Rear auxiliary battery fitted
Extra perm live sockets fitted each side
Extra Fuses & ignition switched solenoid
Rear Red / Amber Led lights
Post #5205 27th Apr 2009 7:37am
Larry
England 2006 Range Rover SE Td6 Java Black
What are the extra rear lights for Ken?
Post #5207 27th Apr 2009 9:34am
I'd also like to know!
I like the position of the rear sticker, seems familiar! Whistle Discovery 4 HSE
Post #5211 27th Apr 2009 12:12pm
ken
Rear Sticker has been there for ages ( http://www.fullfatrr.com/forum/topic148-15.html ) Whistle
Rear Leds are used for the same reason as the fronts Whistle
Post #5212 27th Apr 2009 12:21pm
To pretend you are a rozzer? Mr. Green Discovery 4 HSE
Post #5217 27th Apr 2009 9:32pm
I guess they are not wired up as brake lights or side lights .............. Question Question Question Question Question Question Question
Post #5218 27th Apr 2009 9:45pm
ken
Why on earth would I want to pretend to be one of those
LEDs were fitted fitted to my last two D3s as well and lets just say I use them when the winch is on and working
Post #5219 28th Apr 2009 7:23am
DiscoStu
Cool Love the battery installation - very neat Thumbs Up
Bet you skin your knuckles dropping it in there Shocked Wink
Post #5220 28th Apr 2009 8:44am
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
1. Fusebox very near to antenna? No problems ?
2. Any ECU-stuff necessary for the second battery circuit?
3. Itīs an optima yellow?! When Iīm informed right, it has a total different charging cyclus/modus then normal batteries? So do you modificate the generator or a dual charge system with relay switch?
4. I guess itīs for a fridgefreezer, arenīt the wires a bit too thin - min. 2,5-4mm ?
I ask because I also will install a second battery for my Nat.Luna. For the next weekend-trip I will try it with the original socket for the first time - hope there will be no battery failure and I will return from the Lake... Laughing XJC, RRV8, Series1 86 and 107% of real pleasure
Post #5221 28th Apr 2009 9:01am
ken
1.Fusebox very near to antenna? No problems ? No
2. Any ECU-stuff necessary for the second battery circuit? No
3. Itīs an optima yellow?! When Iīm informed right, it has a total different charging cyclus/modus then normal batteries? So do you modificate the generator or a dual charge system with relay switch? Look at the big silver shiney thing Rolling with laughter
4. I guess itīs for a fridgefreezer, arenīt the wires a bit too thin - min. 2,5-4mm ? that fuse is for the rear Aux sockets and its thin wall wire will take plenty safely Thumbs Up
This system has been implimented on many a D3 albeit in the engine bay. The main reason for the aux battery is the deep draw whist winching nah your right its for the beer fridge as well Thumbs Up
Just remenber mine is an 07 yours is a 03 so your options may vary Thumbs Up
Yellow top is the best type for this aplication
Post #5222 28th Apr 2009 9:27am
delsilencio
Ahhh, okay, thanks Thumbs Up XJC, RRV8, Series1 86 and 107% of real pleasure
Post #5223 28th Apr 2009 6:33pm
