Home > Wheels & Tyres > Best tyre for muddy fields & road - Cooper Zeon LTZ?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I have a 2007 Range Rover Vogue 4.4 V8 Petrol - I'm looking for a good tyre that will get me across clay soil waterlogged fields in winter months but will still be good for road use throughout the year.
Please can anyone advise me on a good tyre for the job?
I'm still running on the original alloys, with 255/55/R19 Pirelli Scorpion Tyres
A recent visitor in a Discovery recommended I buy a set of Cooper Zeon LTZ 255/55R19 tyres - Has anyone else had a good experience with these?
Would also like to hear from others and their recommendations - Please let me know your thoughts?
Many thanks
Post #522918 26th Jul 2019 11:00pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
Can highly recommend them; although they are getting hard to get hold of. "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #522922 27th Jul 2019 12:10am
aja500
Thanks stu_007 - Expensive as well - Seem to be around £330 per tyre!
Post #522923 27th Jul 2019 12:17am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
General Grabber AT3 - Superb on and off road. No noisier than standard tyers either. Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #522933 27th Jul 2019 4:05am
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
+1 for Grabber AT3, I’m surprised how quiet they are on road and not much over £100 each
Post #522938 27th Jul 2019 6:47am
DrRob
I’m going for AT3 next in 255 55 20 to give a bit more wall height. Speedo will also read bang on too Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #522941 27th Jul 2019 7:41am
stu_007
Cheapest place in Craddocks; about £120 a tyre I think. "YYS" G4 FFRR
Post #522955 27th Jul 2019 11:16am
CS
Goodyear Duratrac 255/55R19 is the LR homologated all terrain tyre for the 322, though speed rating is lower than the AT3. I had them on my 322 as my winter tyre and was happy with them. I now have the 255/55R20 version on my 405 as my winter tyre and again am happy, though the speed rating there is even lower. They are a bit noisier and use a bit more fuel, handling and braking less good on road than the Pirelli Sc Verde summer tyres, but OK for me. They have been fine on snow and ice, and on farm tracks and fields, bearing in mind of course that "ye cannae change the laws of physics" - I have known quads, tractors and even an Argocat get stuck. Only Range Rovers since 1988
Post #522968 27th Jul 2019 12:29pm
aja500
Firstly, thank you everybody for sharing your thoughts, it's always much appreciated.
As the thread evolved I had pretty much decided on the Grabber AT3, especially when looking at the difference in cost. However, now stu_007 has come back with a supplier selling Cooper Zeons at £120 per tyre, I'm now torn between the two.
Also, I note CS's reference to the Goodyear Duratrac and a slight increase in road noise - Should this increase in road noise be expected with all tyres of this type, including the Cooper Zeons and Grabber ATS?
If so, I'm wondering whether to change the tyres at all, as the V8 Petrol L322 I have does have a supremely quiet cabin with the Pirelli Scorpions on. My reasons for looking to change tyres is only to get me across 12 acres of grass fields to feed our half a dozen sheep when the weather turns - If I didn't change would my Pirelli's with 6mm tread on manage that?
Post #522997 27th Jul 2019 5:09pm
Worth a try, they do all the LR Experience on road tyres don't they ?
Mine coped admirably on snow and ice with Nexen road tyres - before I got General Grabbers Wink .
Post #522999 27th Jul 2019 5:30pm
CS
Every tyre is a compromise.
Much will depend on the weather and whether your field is flat, is consistent in its firmness (or lack of it) or has boggy patches. Road Scorpions will start spinning sooner than Duratracs, and the tread fills up more easily with mud, and once that has happened they are like slicks. The Duratracs will cut through better, but will cause more damage to the field in doing so, you can easily get deep ruts, maybe less so if you can be bothered to deflate them a bit and then pump them up again once back on the road. Once fields get so soft that I'm cutting through the turf I tend to walk, as it's not fair on the farmer to destroy the surface. That does of course make for much more carrying and time being required.
I would not especially like to run Duratracs all year, so have two sets of wheels with summer and winter tyres. If you want to run the same tyres all year and just have one set, and you like the Scorpions you have, then if I were you I'd stick with those and see how you get on. Most of the time if it is not especially boggy they will be OK. If it gets extremely soft the Duratracs would either make a real mess or you'd get stuck. So the Duratracs will have a relatively small window when they will get there but the Scorpions won't, and it is a case of deciding whether the year round compromise is worth it for that small number of occasions. They are of course much better in wintry weather than the standard summer Scorpions, depending on the weather you normally get they may be worth having for that alone. What I tried to do was to establish a secure and waterproof feed depot near where it would be used, feed off the vehicle if it was possible to drive, but have the feed there if I needed to walk. Only Range Rovers since 1988
Post #523010 27th Jul 2019 7:45pm
GraemeS
Pirelli AT+ are made in 255/55R19. I have them in 275/55R20 on my 2012 and am impressed with their quietness and all-round good performance on and off sealed surfaces. I'm a farmer with a 2km driveway so they need to handle muddy tracks well enough without chewing-up the ground unnecessarily.
Post #523025 27th Jul 2019 10:15pm
aja500
Thank you once again to all for you comments and sharing your experiences with regards to this topic. I think I'm going to try the Pirelli AT+ as recommended by GraemeS.
It appears to be "the new kid on the block" recently developed by Pirelli with an emphasis on low road noise as well as off road capability and the coveted three peak snowflake sidewall marking for improved traction in the snow.
I will let you all know how I get on once fitted - a detailed review for anyone interested is here:
https://www.offroadxtreme.com/engine-tech/...rain-plus/
Post #523041 28th Jul 2019 8:24am
GraemeS
The AT+ is becoming quite popular here in Oz, including the (non-LT) 255/55R19 size that also fits the Amarok which is also popular.
Post #523063 28th Jul 2019 12:06pm
