Home > Technical (L405) > Not sure my air con is working? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
a/c button pressed? ... - .- -.
2nd Oct 2019 5:36pm |
Andy Cox Member Since: 24 Dec 2016 Location: Cornwall Posts: 45 |
i probably should have said that in my original post. Yes, A/C button - ON, Auto - ON. Even if I have 'MAX A/C' on, it doesn't make any difference. I've just been out to try it again there is no perceptible difference in air temp at the the centre vents between a selected temp of 16 to 26 deg.
2nd Oct 2019 6:30pm |
see if switching auto off makes a difference...it could be that auto is thinking its cold enough not to reduce the temperature... ... - .- -.
2nd Oct 2019 7:01pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1260 |
regas i reckon, make sure you have the correct gas. |
3rd Oct 2019 12:04am |
Interesting idea Stan about it deliberately not reducing the temp due to Auto being selected. Will try that today.
3rd Oct 2019 7:56am |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 |
Andy Did you get anywhere with this? I have the same (not) cooling problem on my new-to-me FF. |
4th Nov 2019 5:45pm |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
I thought that a differnce of 10°C (16 to 26) is not excecuted by the system. Can somebody confirm? 2017 Range Rover Vogue TDV8 silicon silver 2011 Defender 90 2.4 TDCI Nara Exclusive 2008 Porsche 911 997 4S Black/black 1970 Porsche 911T 2.2 in restauration 1980 Toyota Land Cruiser BJ40 concours winner |
5th Nov 2019 5:53pm |
@nwmgc Sorry for the delay in get back to this, life's been a bit hectic lately.
14th Nov 2019 6:11pm |
I should get mine back today. It seems it took some time to fix (three days) and I will find out more later. I do know there are problems with the new EU type A/C coolant fitted to our cars which is very leaky (as well as being much more expensive). I know that's what the initial diagnosis was - but will report back. |
15th Nov 2019 11:03am |
Well folks, it turns out it was the pesky-new-fangled-EU gas. The service adviser said 'the sales department have received a very large invoice'. I, of course, am relieved this is all under warranty but will be anxious that the stuff will seep away again. Still, something positive after five days with the stealer! |
20th Nov 2019 4:26pm |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 83 |
Did you say the new R1234yf caused your air con problem ?
15th Jul 2023 1:46pm |
Well, there was a lot more to the story since I wrote in 2019! It went back three times (pandemic didn’t help) over the next two years - even trying an even more useless dealer - and it turned out to be a pinhole leak in the compressor. Naturally, the dealer said it was a recent problem but it’s been fine since (touch wood and all that)… 🙄 |
15th Jul 2023 3:33pm |
