Home > Maintenance & Mods (L322) > How to check soot level (g) TDV8 using a iiD tool
Clubman
Portugal 2011 Range Rover Vogue TDV8 Zambezi Silver
After reading many threads in this great forum, I tried to check what level my car is at, but so far no luck.
I've bought a iiD tool BT, update with the latest firmware.
In live values I only see two options that mention soot, one says DPF filter soot concentration : it reads 0 .
the other, says soot level in oil : N/A ;
what am I doing wrong ?
Tito
Post #531591 20th Oct 2019 11:14pm
DrRob
With latest software installed look for "Diesel particulate filter soot concentration - inferred using differential pressure" Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #531600 21st Oct 2019 7:56am
Dolphinboy
You need to go to look at live values, then engine then highlight the field (diesel particulate filter soot concentration) you want and then click lower left to view (bottom right in my picture)
http://www.fullfatrr.com/gallery/albums/us...G_1355.PNG
Post #531620 21st Oct 2019 11:36am
Clubman
thank you for your replies, today, after some motorway driving, when I arrived home I connect the iid tool, and this is what I got
according to this the DPF is completely clean !
is it suppose to be that low, or is there something wrong with this picture.
Also something that bothers me , is the voltage is always very low, 12,7 has you can see on the picture, while Dolphinboy's image is showing 14,7, much higher. I wouldn't expect that much, but at least well inside the 13 v range.
Post #531736 21st Oct 2019 10:56pm
Range Rover L322
I believe the Soot in Oil is not populated so you can ignore that. The DPF filter soot concentration however is never Zero - that's very odd. Do you have the latest update from GAP on your IIDTool?... Perhaps your DPF has been bypassed - this would be a first on here. Be aware bypassing or deleting a DPF on a car that came with a DPF can get you in trouble, although no-one's quite sure how anyone could tell it's been done.
It is such a monumental can of worms getting into the whole DPF issue, that if you are not getting Yellow DPF Full Warning Lights on your dashboard this is an issue it is best to leave alone.
If, however, you insist on investigating you want to get "Number of Demanded Regens up" and the "Exhaust Gas Temps" - there are 4 x EGT sensors .. the most important is "Exhaust Gas Temp - Bank 1 - Sensor 2". Watch that sucker fly up to 650ÂșC when it demands a regen.... that will help you start figuring out what is going on, although, again, this is something that you are better putting down to Magic and Wizardry than investigating. DPF is a Dark Art; there is some funky Factory ECU programming involved that is highly misleading.
Post #531742 22nd Oct 2019 1:13am
Clubman
Thank you for you advice, I'm starting to think that this car is best left alone, but I'm used to do preventive maintenance in all my previous machines, never having a major failure before, maybe because of that or simple luck.
I will check the data you said, woulnd't be surprised at all if the DPF has been removed. I've got a one year warranty from the dealer that sold the car, how can I be sure the DPF is there or not , so that i can complain with the salesman ?
Post #531759 22nd Oct 2019 9:25am
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Worth checking under the car to see if you have a DPF.
I had the same thing when checking the soot levels with the IID.
I then found out I didn't have a DPF fitted, apparently up to 2011
buyers had the option of whether to have one fitted or not.
I was glad to see that option had not been ticked
Post #531771 22nd Oct 2019 12:23pm
Clubman
Ok Will go under the car tonight . Now from someone else that never had a modern car , what am I expect to find ? In other words , how does it look like ?
Post #531773 22nd Oct 2019 12:42pm
Range Rover L322
I thought DPFs were mandatory since 2009... but I could well be wrong.
Firstly if the DPF has been bypassed you wont be able to tell unless maybe with a borescope.
Secondly - neither will the MOT inspector be able to tell! -
Thirdly - ignorance is bliss. If you do not know the DPF is not there and you did not remove it you have a strong case that its absence is not your fault. However if you know you are running a car that by law is supposed to have a DPF and you have not re-instated it you could be culpable...
Fourthly. If someone has deleted your DPF and re-programmed the ECU, re-instating it will be a pain in the ass.
Fifthly, if our friend above is right that DPF's were an option, happy days!!
I hear you about doing preventative maintenance. It's my preference too, however I have learned that Range Rovers are best run with a "if it isn't broken don't fix it" mentality for the complicated bits as they are mostly Factory Manufactured from Cans of Worms... stick to Waxoyling and replacing the gas struts!
Incidentally, if it matters, I know it is not particularly environmentally friendly but there are a few owners out there who wish they didn't have a DPF...
Post #531805 22nd Oct 2019 4:43pm
Nick591
If you have DPF you will have a canister in each exhaust one either side of the auto box with a temp sensor in the pipe before it and after it. Can't miss them. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #531853 22nd Oct 2019 10:09pm
Nick591
Post #531854 22nd Oct 2019 10:10pm
Range Rover L322
Nick591 makes a good distinction - I think he is referring to a 3.6 TDV8 with 2x DPF boxes?
I am talking about the 4.4 TDV8 which has only 1 DPF box Drivers side just aft of the drivers door.
Post #531935 23rd Oct 2019 9:03pm
Nick591
Yes I was talking 3.6. I guess if the op has a 2011 car it will be 4.4. Apologies. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #531946 23rd Oct 2019 11:35pm
Clubman
well, if that is the DPF, then I don't think my car has it . Here's some pictures i took just now
I didn't noticed any sensors around those two boxes.
On the first picture, there's a box only on the right side of the engine, and when the two sides meet, there's this little one of the second picture !
What do you guys think ?
Post #531949 24th Oct 2019 12:29am
Baltic Blue
The 2010-12 workshop manual clearly shows both exhaust system layouts,
With DPF fitted and without DPF fitted.
Post #531960 24th Oct 2019 9:31am
