Home > LPG > 4.4 Jag and SC owners on LPG
Page 2 of 4 <1234>
Dolphinboy
I have a stag system on my bmw 4.4 v8. It was fitted by Autoprofessgas who are located just north of Cardiff. They are Polish and know their stuff and a closer to u in brum. 👍
Post #511991 13th Apr 2019 11:27pm
Peopete
Thanks for the advice Thumbs Up
Post #511999 14th Apr 2019 8:00am
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I had a prins system fitted by a guy called Matt who is in Birmingham. His attention to detail was fantastic. The compressor was moved to the side box under the boot floor with a specific mount to dampen as much sound as possible, its been fantastic so far.The doughnut tank went where the spare wheel would have been. This meant I didnt lose any boot space.
I have done 16,000 miles with no issues at present. This system does have the auto lube system fitted.
It cost me £2500.
PM me if you need Matts details. He works with PRINS only. #
Check out - http://www.prinsautogas.com/en/products/vs...ystem.html Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #521731 14th Jul 2019 9:35pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Friskydog, how have you found LPG on your SC RR? I'm thinking of getting mine done and am close to Brum.
Post #532620 30th Oct 2019 9:37am
friskydog
It's been a god send. And the guy that did mine lives only 1 mile from me. It's way passed paying me back already. I used a 90litre doughnut tank in spare wheel in boot and moved compressor to side box in the boot. If you need me to send details of Prins guy PM me and I will gladly supply. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #532713 31st Oct 2019 8:03am
Gsxr1250dave
I cant add any more to this as iv the 4.4 m62 engine but it's good to see peeps still installing lpg on there cars
Post #532731 31st Oct 2019 11:10am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Had my 4.2sc on lpg with lube system never ran out after 60k valves seat eaten away dead engine, be careful these seat are really soft.
Post #545387 27th Feb 2020 10:02pm
friskydog
What Lpg system did you use btw. Just wondering as my recent one is the recent Prins Vsi Model.
I am at 20,000 miles now on mine. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #545388 27th Feb 2020 10:20pm
lighthouse
I had a Romano system, with flash lube, full return system worked great even had petrol mixed at higher rpm to offset the calorific value of gas vs petrol to retain top end performance. It
But the seats just too soft.
Post #545395 27th Feb 2020 11:04pm
dingg1
45000 miles so far still no issues Smile
Post #545415 28th Feb 2020 10:20am
lighthouse
Mine was fine for miles not a missed beat, i did change plugs every 15000 miles as well as other regular service items, I used good brand flash lube and never ran out.
At about 55,000 miles of use i started getting odd misfire, started on number 7, it was only every now and again then it got worse then i got misfire on number 4 and then started getting them on all cyclinders, did a compression test and number 7 was really low at about 60,000 car went into limp all the time, 62,000 car was no longer driveable sold it for parts, took the heads off valve seat were pitted and eaten away.
I also used to used 1 in 5 tanks of petrol so 4 tanks gas 1 tank petrol to give it natural lube, i thought i followed all the guides to reduce risk to the heads but they still went.
Just passing on my experience so that hopefully others can avoid my pain.
My time on gas was painless and no issues until the end.
Post #545422 28th Feb 2020 11:26am
dingg1
That's a shame, perhaps people usually move them on before they see symptoms or maybe you've been a bit unlucky, I've just spent a few bob on mine and it's now looking pristine, so I'll be keeping it for a good while unless something terminal happens.
You don't hear too many having problems tbh, maybe they keep it to themselves though.
Did you have any issues with it running lean?
Was the cel working ok?
Post #545432 28th Feb 2020 12:13pm
dingg1
Forgot to ask how many miles in total when it died?
Post #545436 28th Feb 2020 12:16pm
lighthouse
No issues with it running lean, i had the system configured so bleed in petrol whenever there would not be enogh calorific value in gas to give the required response.
I used to monitor it a lot and service gas filter regularly and frequent plug changes.
It was 121,000 when i died, i brought the car with 58k on it and had the conversion done.
I am not trying to put people off lpg its great and makes running the big beasts cheaper. Just sharing my experience so others can learn. If i did lpg again i would probably do a more 1 in.3 petrol tanks to help protect the valve seats, theres no right answer but LPG is great i even had my own skid at home as was paying 35p a litre.
Post #545440 28th Feb 2020 12:45pm
Danwilderspin
Lighthouse - wouldn’t it have been worth getting the buckets done or new seats hardened seats fitted rather than scrap it? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #545639 1st Mar 2020 9:13am
Page 2 of 4 <1234>
