Home > Technical (L322) > L322 td6 non start issue |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Any chance you've got a blown a fuse either through the pump failing(shorting internally) or shorted a positive wire when the pump was changed ? I would check your fuses if you haven't already. |
11th Nov 2019 11:13am |
Fuel pump , Fuse 51 , 10 amp located in the passenger compartment fuse box. |
11th Nov 2019 11:15am |
Also rear loadspace fuse box , Fuse 85 , 25 amp. |
11th Nov 2019 11:17am |
jefus957 Member Since: 21 Oct 2018 Location: Stoke on trent Posts: 16 |
Thanks mercs600 will check fuses again later and see if they’ve blown, have changed avo foreign meter and am getting a lowing voltage so that seems ok... |
11th Nov 2019 11:28am |
Update checked fuses both ok, checked ecu relay voltage on red wire and the 2r/w wires 12.5vt,but no volts on the ecu injector plug terminals or the r/w wires when plug is in situ..got injector system fault on dash display but as stated before no faults showing on my I-carsoft LRV2 scanner tool,have replaced all injectors which led me to check for voltage at injectors none then onto ecu, beginning to think it is the ecu, seen them on eBay with same numbers but am wary to get one, not sure if it will affect the keys etc..the joys of ownership |
11th Nov 2019 5:44pm |
On my TD6 the large black housing in the engine bay on the left hand side which has an ECU has a fuse. Worth checking. Mine maybe an addition as mine has been chipped |
12th Nov 2019 9:33am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
After fueling up one day a few years ago, I drove a few hundred metres down the road and the engine cut out.
12th Nov 2019 8:55pm |
Not done any work on motor for couple of months still got back to problem with no start, in the end it’s turned out to be a broken wire connection on injector rail sensor plug, starting first time every time now hurray, just got sort out water in the channel below Nsr kick plate, sealed sun roof up as not used so at mo baffled will av research and c if I can find source always something with rr but still love em... |
12th Jan 2020 9:36pm |
