Home > Technical (L322) > FOUND REASON!Smoke from left hand side and fumes in cabin???
dazza1983
So land rover when looking for my coolant leak which never was, took apart the egr system and when refitted the tube they crushed the flange which resukted in exhaust fumes leaking but only noticable when hititng the throttle hard..
Just had a little fright. I started smelling diesel fumes in the cabin and then I noticed smoke coming from under the bonnet where the battery is located. After a few mins it stopped and when I had a chance I pulled over and checked under the bonnet. I can’t see anything obvious but WTF????
This was 25 mins into a drive.
I did give the car a good blast through a couple of gears. Full rev range. Not sure if that would have caused anything. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #534241 14th Nov 2019 5:30pm
mjdronfield
Not sure really, but the fuel burning heater is under where the battery is, under the wheel arch and it has its exhaust there too. You prob know that already......and I’m not sure it would still be running that long after startup, so may be a red herring...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #534243 14th Nov 2019 5:34pm
DrRob
Probably the FBH now that weather is colder. Exhaust is behind passengers front wheel. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #534244 14th Nov 2019 5:39pm
dazza1983
Wonder why the fbh would kick in or still run after that time. Engine was well up to temp.
Only thing was a couple of times the temp dropped to 4 when the ice icon appeared on the dash? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534249 14th Nov 2019 6:14pm
dazza1983
Anyone else ever experienced this.
It seemed fine on the way home. Just like to understand what the heck happened. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534265 14th Nov 2019 8:33pm
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Itll be the FBH, mine does the same from time to time even after a drive
Post #534395 15th Nov 2019 8:20pm
dazza1983
Cheers matty.
No adverse effects from this? Your fbh works ok?
I’ve done a few miles since yesterday and repeat smoke or smell. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534398 15th Nov 2019 8:33pm
dazza1983
Blooming car did this again today.
It can’t be right ???
Diesel smell in cabin is not good.
Anyone offer any more insight into this? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534504 16th Nov 2019 9:42pm
DrRob
Have a look over on Disco 3 forum. They have a FBH section Thumbs Up
https://www.disco4.com/forum/webasto-fuel-...33e8cb2cb2 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534532 17th Nov 2019 10:05am
dazza1983
ok, so had the wheel arch liner off and got the wife to rev the card hard and violently and the smoke and diesel smell is coming from the rear of the engine, a rough area guess is undernerath the pollen filter chamber area.. anyone any ideas??? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534557 17th Nov 2019 1:05pm
Oil cooler ? .
Post #534620 17th Nov 2019 8:09pm
dazza1983
Egr tube joe.
Land Rover tech has crushed the flange by not seating the clamp correctly. After some hard throttle it smokes and fumes into the cabin.
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534622 17th Nov 2019 8:12pm
DrRob
That’s is one serious safety issue that I would play merry hell over! Diesel fumes in the car is a big no no.
I would be asking for a new part and fit it myself. Not the Censored monkeys at the main dealer Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534624 17th Nov 2019 8:18pm
