Home > Technical (L322) > Drivers door switch pack problem |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
What's your car moddel, and peerhaps you could update it in your profile.
31st Dec 2019 10:31am |
Shambler Member Since: 04 Nov 2017 Location: Gloucestershire Posts: 41 |
My car details are set in my profile but don’t seem to show in posts?? It’s 4.4 petrol vogue 2003
1st Jan 2020 2:37pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
BCM, have you checked Fuse 41, 5A? |
1st Jan 2020 3:27pm |
Thanks, I’ll check fuse again, seems to be a lot of different fuse options from different web sources, may try disconnect BCM again see if it resets? |
1st Jan 2020 4:08pm |
Checked fuse 41 but doesn’t say it’s for door switch pack, can’t seem to find anything related to drivers door or switch pack on my fuse chart?
1st Jan 2020 4:34pm |
The fuses that could affect the drivers for switch panel are F11,30A : F41, 5A : F53 30A.
1st Jan 2020 6:26pm |
I’ll give those fuses another check tomorrow and have another look at the BCM and give the wires a wiggle and try the battery again, I did disconnect it for a while yesterday but it didn’t make any difference, but after a wiggle of cables it might
1st Jan 2020 6:38pm |
Update:....
2nd Jan 2020 5:38pm |
2nd Jan 2020 9:55pm |
Yep |
2nd Jan 2020 11:04pm |
Need to get it plugged in, I have an icar gizmo but not sure what or where I’m looking for results tbh, |
3rd Jan 2020 11:43am |
Just a thought.
3rd Jan 2020 12:01pm |
Oddly I do have alternator issues... the battery light is constantly on but the readings taken at the battery suggest it is charging ok, it always starts and has never gone flat in the 2 or so years it’s been like it? I have another alternator to fit but as it seems quite a fiddle have never gotten round to it....would a fault code reader tell me if that was the problem? I have toyed with getting an iid tool but haven’t got round to getting one yet, I do however have the icar code reader thing, but again not really sure what or how to check codes |
3rd Jan 2020 1:02pm |
A voltmeter connected to the battery would be useful, even a plug in unit plugged into a cigar/accessory socket.
3rd Jan 2020 4:48pm |
