Home > Maintenance & Mods (L322) > MOT advisory - front brake pipes
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Big Cry
As above, had the following advisory guys on my 2003 TD6:
Brake pipe corroded, covered in grease or other material Nearside Front [1.1.11 (c)]
Brake pipe corroded, covered in grease or other material Offside Front [1.1.11 (c)]
I've found Joe90's great guide Bow down Is it worth replacing the flexi's and clips at the same time when I do them? (when its warmer, and drier!)
Post #541557 23rd Jan 2020 11:16am
Yes Thumbs Up .
Post #541560 23rd Jan 2020 11:24am
mrblonde
Thanks Joe, oh and great write up by the way!! Thumbs Up Bow down Thumbs Up Bow down Thumbs Up Bow down
Post #541566 23rd Jan 2020 11:55am
he's definitely the forums expert on brake pipes... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #541568 23rd Jan 2020 11:57am
WB
I've got a pair of front Flexi's for sale - they were bought for a 2008 TDV8 and never needed but you'll need to check if they're the same? Could do you a deal on them.
Post #541608 23rd Jan 2020 4:19pm
sad, isn't it Laughing .
Post #541611 23rd Jan 2020 4:45pm
ah, but not if its your chosen subject on mastermind and you get all the questions right.
Mr. Green Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #541612 23rd Jan 2020 5:05pm
but then I would have the general knowledge to worry about (actually - could do better at that Wink) .
Post #541643 23rd Jan 2020 8:39pm
mrblonde
Joe
I see you made yours up yourself, i replaced my front to rears last year and made them up as imagine it was a pig to route the originals due to their length and flimsyness
Is it easier to make up the fronts, or being shorter could genuine LR ones be manipulated into place easy enough?
Post #541788 24th Jan 2020 8:57pm
The passenger side you could probably jiggle an original up to the ABS unit, whilst the drivers side would be a nightmare to do with the steel pipe. Some say they did it... (on the 3.6V8 there were short pipes and joiners on each side, so I was able to jiggle my new (home-made up) pipes up through the gaps)
What you could do, which would be similar to the setup on the 3.6, with the correct type of flaring tool, is make a cut in the engine bay by the wheelarch on good metal, and flare the original pipe (put a fitting on first!) and make up a piece to replace the bit you cut off. This is if the pipe in the engine bay is in good order and just rusty out by the wheel. Otherwise replace the whole pipe with bendable cupro-nickel.
Post #541814 25th Jan 2020 1:19am
