Home > Technical (L322) > MOT Fail L322 TD6 Rear Brake pipes corrosion from caliper on
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Obscure description but sounds like my local is scared of the job! Are they a special part from LR or can they be made up?
What sort of job? Defo ramp job so any recommends?
Post #541726 24th Jan 2020 2:25pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
There are two parts of hard line on the rear of these, one pair of long sections running from the front nearside wheel arch to the rear corners and then a short section of hard line strapped to the suspension arm between two flexible hoses. Easy enough job to replace, I've done mine while the car was on axle stands.
Post #541727 24th Jan 2020 2:58pm
bleeperman
These being mild steel are they shippable parts?
Post #541729 24th Jan 2020 3:08pm
Replace the original steel pipes with copper pipe and that should last the life of the car, then replace the flexi pipes with new from the MD or alike... Thumbs Up
Post #541731 24th Jan 2020 3:24pm
bleeperman
That's what I thought but the local seems to think its not a standard set up?
Post #541733 24th Jan 2020 3:40pm
kezbo1981
Appeared pretty standard to me. I'd have thought you can get steel sets from LR, or as Craig says us copper or cunifer.
Post #541741 24th Jan 2020 4:29pm
TomCobbly
I read somewhere that you shouldn't use copper with antilock brakes as the pulsing can case harden the copper. Cunifer is fine apparently 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #541744 24th Jan 2020 4:34pm
darrenm
Juat make new ones up using Cunifer and new flexible pipes easy
Post #541748 24th Jan 2020 4:45pm
bleeperman
Ta
Guys local must be too busy, if you want something doing....,..
Post #541749 24th Jan 2020 4:46pm
