Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
Greg, Rovertune specifically checked for those O ring leaks at turbo end of pipe for me. Unfortunately the turbo leak was from the main turbo My advice would be to run it out to them in Reading one day for a diagnosis. They might have their customer office area open upstairs by now And you can do a DPF run Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
26th Jan 2020 2:49pm |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 |
Are they the same for the l322 and l405? |
26th Jan 2020 4:00pm |
AlanS Member Since: 23 May 2019 Location: North Lincolnshire Posts: 18 |
If you have the TDV8 4.4 diesel, they are the same as far as I know. The part number for the L322 is LR022895. They said the fit these 90% of the time and never had a return or an issue. 2012 L322 4.4 TDV8
26th Jan 2020 4:04pm |
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 |
Thanks for this - I have the oil weep on a 2012 TDV8. Just wondering whether it’s best to fit this whole unit - or just the new gaskets back onto to the original parts? Does it make fitting that much easier to change out the whole thing? Matt |
28th Jan 2020 8:36am |
My mechanic mate who did mine always fit entire new unit and gaskets. I was happy with that. Some folks just do gasket. Personal choice dependent on bank balance Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Jan 2020 9:06am |
The gasket change is easy enough. A few more bolts to undo. You have an extra surface to clean. Not much extra work and it's only simple. Easy to do once you have the oil cooler out. One piece of advice, be careful when you put the pipe with the two O rings back in. I cracked the cast aluminium part that the pipe goes into. Hence the new oil cooler. Also, there's a coolant pipe that runs from a fitting the the donut shaped air intake pipes and goes to a rubber hose at the front of the vehicle. The fitting that Recieved the small stuff pipe into the large rubber pipe is VERY brittle. It's £80 for a new part so be careful. Don't ask me how I found it was brittle. Sigh. 2012 L322 4.4 TDV8
28th Jan 2020 9:50am |
Great intel - thank you very much! |
28th Jan 2020 9:58am |
So can anyone confirm if the 8.73/1.78mm viton O rings fit without leaks????
6th Feb 2020 10:54pm |
Lots of people fit the smaller ones and get on ok with no leaks. If I was you, I would get the slightly larger ones. They will still fit ok. Just lube them well and take care sliding them in nice and straight. The difference between the 2 you mention is very small. 2012 L322 4.4 TDV8
7th Feb 2020 12:22am |
Cheers alan |
7th Feb 2020 8:40am |
Kevio Member Since: 18 Feb 2020 Location: Wiltshire Posts: 10 |
Phase 1 is complete following mm289's guide. i.e. i have the intake manifold off. Rain stopped play but i'm hopeful it will pass,
18th Feb 2020 2:22pm |
Hello,
18th Feb 2020 2:34pm |
Thanks for the fast reply Alan, and the reassurance. much appreciated. my main concern is making sure i dont get coolant in the engine.
18th Feb 2020 3:12pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
This picture shows where the oil pipe fits into the cooler.
18th Feb 2020 3:14pm |
