Home > Maintenance & Mods (L322) > Flip key conversion |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 424 |
I bought 2 flip keys from Dave back in 2016 https://www.fullfatrr.com/forum/topic10413.html, but I didn't manage to do the flip key conversion back then, and now I thought I would give it a try once again.
18th Nov 2019 6:51pm |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 |
Check the battery as if its low the key won't turn 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
18th Nov 2019 10:34pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Check the length of the blades carefully, I suspect your new one will be a different size Current: 2011 FFRR Vogue SE 4.4 TDV8
20th Nov 2019 9:04pm |
Thanks Bushy - will do!
21st Nov 2019 8:21am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 652 |
I have the same problem, made sure I had new batteries in both key fobs, and the blades looked like they were the same length, but to be sure I get my digital calipers out and the new key is 1mm shorter - I thought nothing of it and pressed on
1st Feb 2020 11:53pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I Did a flip key conversion on my 2003 , same by using the existing transponder chip into the new fob, but then had to do the key synch for it to be used in the ignition. |
2nd Feb 2020 12:58am |
is this the sequence
2nd Feb 2020 1:10am |
