Home > Technical (L322) > What does this part do?
Dolphinboy
Have a restricted performance pop up. Some black oily residue on these 3 pipes and below on the manifold. Have tried to find out what this part is (behr make LR designation BH42-9B262AJ) to no avail. Anyone know what is is called and what it does? It’s on the right pax side.
These are the 3 pipes covered in oil
Post #545697 1st Mar 2020 7:14pm
Weegie
Fuel cooler PN LR031827. John
GAP iiD BT
Post #545698 1st Mar 2020 7:26pm
Weegie
Double post John
GAP iiD BT
Post #545699 1st Mar 2020 7:26pm
Dolphinboy
thx John. is a leak likely to lead to RP? Even when not in RP it seems underpowered. Could it be a simple leak or is it more sinister?
Does it involve actual fuel in these pipes or just oil? I have had a strong smell of diesel at times.
Post #545703 1st Mar 2020 7:48pm
Weegie
If there is a leak then I would think that the fuel delivery would be affected which in turn could lead to RP and loss of performance. John
GAP iiD BT
Post #545707 1st Mar 2020 8:01pm
They are your fuel pipes James, coming from the diesel fuel cooler unit and should be under VERY high pressure sir... Thumbs Up
Post #545734 1st Mar 2020 11:25pm
Dolphinboy
Thanks Craig. Have checked alignment and fitting - if they are high pressure lines do they have an o ring which could split/leak?
Post #545760 2nd Mar 2020 10:06am
