Home > Maintenance & Mods (L322) > How to remove a scratch?
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Yesterday as I was driving along a truck at the front of the line of cars dropped a load of mud off the back and onto the road.
With the damp roads the car in front of me threw up a load of muddy spray and there was grit in the mud. The wipers came on automatically and now I have a long shallow scratch right across the passenger side of the screen in an arc........... is there anything I can use to polish it out as although very shallow it is very annoying. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54790 15th Mar 2011 12:52pm
you could use jewellers rouge or branded glass polish from t-cut for instance but whatever you do use you run the risk of making that part of the windscreen more 'shiner' than the rest..i would have a word with your local windscreen supplier first and get their advice.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #54792 15th Mar 2011 1:04pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
as Stan says - a branded glass cleaner but with a rotary polisher (made a similar post minutes ago to Dan Smile )
but do the whole screen for an 'even' finish
shame your not near me as i'd do it for you!
Post #54795 15th Mar 2011 1:13pm
Tim in Scotland
I'll take a trip to the local windscreen crowd then and see what they have to say. Thanks for the advice. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54796 15th Mar 2011 1:26pm
nick h
best of luck if its the monkeys at Autoglass Mad
they replaced the windscreen of the GC and managed to gouge a 'back to bare metal' groove in the bodywork - actually done by the manager himself!
Post #54797 15th Mar 2011 1:33pm
Hope this is not too off topic but anybody got any tips for a bodywork scratch I have in the Black D3. Its too deep to polish out but to small (2 inches) to really warrant respraying the rear quarter panel. Any ideas?
Post #54800 15th Mar 2011 1:41pm
Touch it in with paint then cut back and polish up....Invisible repair Thumbs Up
Post #54802 15th Mar 2011 1:46pm
OK amateur paint shop man here so may need further help:
1. Clean area with spirit to remove wax & crap
2. wash with clean water and dry.
3. Start to apply correct colour code paint into scratch with cocktail stick
4. build up very slowly allowing it to stand proud.
5. Allow to dry for ages (not sure how long)
6. Gently cut back with scratch polish or T-Cut until level with paintwork.
7. Wax polish whole panel.
8. Feel very pleased with self!
Is the above a good plan or have I missed anything?
Post #54804 15th Mar 2011 1:53pm
dan_uk_1984
Wait a week before applying the wax - this will allow the paint to go fully off. Less of an issue with touch up paints as the area is so small, but still worth sticking to the basics.
Post #54805 15th Mar 2011 1:56pm
nick h
a few points if i may?
clean with IPA - nothing else
use paint from aerosol - not touch up stick
'cut' in with a rotary polisher using say Poorboys SSR2 - a machine will do it better/easier than you could ever do by hand
if you've gone a bit 'heavy' with the paint i'd use 2500 grade wet and dry paper to remove the'bulk' before machine polishing
Post #54806 15th Mar 2011 2:07pm
OOps not got a rotary polisher!
Post #54807 15th Mar 2011 2:08pm
nick h
28 days is recommended if you still use non water based paint - but a small scratch should be ok done earlier
Post #54808 15th Mar 2011 2:08pm
nick h
buy the Megs one with a set of pads
with these 'amateur' machines you cannot 'burn' the paint if you linger too long in an area
you will also be able to use it to remove swirls/holograms/minor scratches from all your cars
will save you a fortune
Post #54809 15th Mar 2011 2:10pm
IPA is available at Maplins: http://www.maplin.co.uk/isopropyl-alcohol-28994
Post #54810 15th Mar 2011 2:11pm
Any ideas where best to buy Nick?
Post #54811 15th Mar 2011 2:11pm
