Home > Maintenance & Mods (L322) > What type of jack do you use? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
Looking to buy a workshop jack for lifting the car onto my new axle stands (swapping wheels, brakes etc) and wondered what type is best to get, the scissor jack supplied in the boot lifts it high enough but is hard work.
12th May 2009 2:06pm |
I’m shocked that LR would allow the RR to leave the factory with the death trap that is the factory jack…. I have heard horror stories of the thread stripping and the vehicle collapsing from more than one person. Also in my personal experience as the jack lifts the car at an angle it wants to push the jack out sideways, if the jack is on concrete with no grip the jack will slide.
12th May 2009 2:19pm |
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 |
The scissor jack that comes with the car is pathetic to say the least!! I've used it only once and the threads stripped leaving me with an almighty job to get the bloody thing back down..in fact I had to use that much force to lower it down that the flimsy handle simply snapped!!
12th May 2009 2:41pm |
Dan
12th May 2009 4:09pm |
It's a crap Halfrauds one, but to be fair it only just lifts the car since some of the oil leaked out! It's ok on the back because I use a wooden block. When jacking from the back I lift right under the spring so its lifting the wheel, rather than the body. Under the front although you're lifting the subframe, that's basically the body too so you still have to lift it loads. A decent mechanics jack would do the job fine, but isnt the sort of thing you can put in the boot. I will generally use a wooden block and then lower it onto axle stands before doing anything to it. Dan |
12th May 2009 4:18pm |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
Cant see the pics guys as I'm at work but please take it from someone who jacks cars up all day long only use the proper jacking points not wishbones etc
12th May 2009 4:34pm |
It's not on the Wishbones, it's on the Subframe (which is the strongest point of the front. When Land Rover jack the car they use the center jacking point - the flat section on the front subframe) One would not use the sill jacking points to lift the car in a workshop environment, to do so would be dangerous, stupid, and damaging in the long term as the stresses exerted through the body in this un-natural state will stress the body (unless you were to lift the whole front, eg a jack under each sill) The rear wishbones are more than up to the job of lifting the car (they do it all day long) obviously one has to exercise caution and common sense and use adequate load spreading, and placement of the jack in an appropriate area as not to cause damage or excessive stress |
12th May 2009 5:20pm |
Hum think my one goes a bit higher than 330mm
12th May 2009 5:41pm |
Ken,
12th May 2009 5:58pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Anyone used or had experiance of those inflatable bag jacks? |
12th May 2009 8:00pm |
Dan sorry you are wrong with your facts stick to IT Chap I'm horrified at your recomended way but its your car
12th May 2009 10:52pm |
Fortunately my IT skills are universal and allow me to count (at least to 10 using fingers) if you read my post carefully you will see that I actually said four "point" not four post, as I could see quite clearly that you have two posts.... and the four points I was referring to were the four points of contact on the car, thus lifting it safely and squarely. I really have no interest in getting into some sort of competition here, and am somewhat confused as to what sort of point you are trying to make? The OP asked what jack to use, I replied and elaborated with what I thought was a helpfull post to him and the board in general. You then snubbed my information, citing that because you lift the cars every day you are clearly the expert. Well I doff my hat to thee. Now hopefully when I've finished sobbing in my pillow I will be able to get on with my life |
12th May 2009 11:03pm |
Dan well said
13th May 2009 6:51am |
13th May 2009 7:40am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1071 |
Now now girls stop sqabiling, kiss on the cheeks and make up letters not necessarily in the right order |
13th May 2009 8:45am |
